Old 10-22-2013, 07:07 AM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Frame Dimensions 2WD
Are the frames for a 1967 to 1972 2WD Suburban and a 2WD long bed pick up interchangable? (It is understood that the 1967 frames do not have provisions for a power steering gearbox)
Rich
1972 K5 Blazer CST Click HERE
Old 10-22-2013, 09:28 AM   #2
budnikguy
budnikguy's Avatar
Re: Frame Dimensions 2WD
No, not without modification...
budnikguy is offline   Reply With Quote
Old 10-22-2013, 06:48 PM   #3
68 TT
Still plays with trucks
68 TT's Avatar
I believe there my be a manual steering frame and a power steering frame for the 67's.
Both my 67 C10 truck and 67 C10 Suburban have the clearance dimple provisions needed for a typical power steering gear box and are unmodified original frames. The partial VIN on both are correct and are 67's for sure. The truck SPID did not show PS as an option but the Sub did. I have put newer power steering gear boxes onto both and they fit perfectly with no mods. I have seen other 67 frames where the PS gear box did not clear. Might be one of the common GM shortages during production situations where they substituted a power steering frame into a truck that did not call for it because the correct part was not on hand when needed.
The front section of the truck frame interchanges but the back half kicks up & back down where the Suburban frame stays flat after the kick up. Back half body mounts are different between the two as well.
What are you trying to do that needs the frame swap?
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 10-22-2013, 08:06 PM   #4
mcmlxix
mcmlxix's Avatar
Slightly entertaining a Suburban after the Blazer is done. I want a slant nose and if I keep with a 67, no emissions testing is needed... but would miss out on power steering... It would have been been easy to find a long bed truck frame for a swap...
Rich
Old 10-22-2013, 08:45 PM   #5
budnikguy
budnikguy's Avatar
I have a suburban frame, roller or non roller...food for thought
Old 10-22-2013, 08:59 PM   #6
pritch
pritch's Avatar
It's super easy to put the power steering on the non-dimpled frame: just heat it up and massage it a little with a BFH and make your own dimple.
Another way, though not usually recommended is to simply shim the p/s gear out until it clears. 'They' will all say that it changes the steering geometry, but I did it on a '67 years ago and it was fine. Just sayin'.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 10-22-2013, 09:16 PM   #7
mcmlxix
mcmlxix's Avatar
maybe just Portebuilt and call it done ... lol
Rich
