Old 10-23-2013, 01:21 AM   #24
JellyBeanDriver
Re: Engine Temperature: What do you guys get?
Ours runs 190-220 depending on the load/hill (just before center to just after center on the dial)
Note that on ours the stock sender location is in the cylinder head between #1 and #3 and runs hotter than the actual coolant temp at the thermostat/water outlet.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
