Old 08-14-2013, 08:09 AM   #1
ab_70chevy
Why dont I have heat?
I'm not real good with AC and heat. My blower works fine, low, medium, and high, but the air blowing is not warm. It's on the cooler side but not cold. AC works kind of. I need a new compressor. But no warm air. Any suggestions on where to start looking?
Thanks fellas
-Andrew
ab_70chevy is offline   Reply With Quote
Old 08-14-2013, 08:45 AM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Why dont I have heat?
A couple of things come time mind:
Is the coolant level OK?
How long do you let it run to check the heat? If the t-stat is stuck open it will take the engine a lot longer to get to operating temp. Also how is the engine temp? Is it at least 180 degrees?
You should have a vacuum operated heater control valve if your truck has AC. Is there a vacuum source hooked to it and does it work? Have you felt the heater hoses, in and out? Are they both the same temp or is one hot and one cool? If you are unsure about the heater control valve, remove it and run a straight hose from the heater core to the engine and see what happens. If you have one hot and one cool in this case, the heater core may be plugged
Is the cable for the heat door moving the heat door in it's complete motion? Sometimes the cables can get stretched and not move the heat door properly.
Make sure the above mentioned items are good and then we can see what needs to happen.
TBONE1964 is offline   Reply With Quote
Old 08-14-2013, 08:46 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Try the simple things first. Coolant level, also check the heater valve to see that its opening and not plugged.
Tom Vogel is offline   Reply With Quote
Old 08-14-2013, 09:34 AM   #4
68350
68350's Avatar
If you turn ur controls to defrost do you get any kind of antifreeze smell or an antifreeze residue on the inside of your windshield? That's what happened in my 78 ford and the heater core was shot.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 08-14-2013, 02:42 PM   #5
ab_70chevy
Thanks for the info fellas. I'll look into it, and see what I can find out.
Old 08-14-2013, 02:58 PM   #6
Drewski23
ive heard this mentioned before but why would a clogged heater core cause that? I havent experienced an anti freeze smell but i am re doing the heating system (it has never worked since i bought the truck) so i was just wondering
Drewski23 is offline   Reply With Quote
Old 08-14-2013, 03:08 PM   #7
SS Tim
SS Tim's Avatar
If you don't have a factory manual, download a copy here. There are lots of pages on the HVAC syatem.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 08-14-2013, 04:35 PM   #8
68350
68350's Avatar
My heater core was leaking it wasn't plugged.
Old 08-14-2013, 08:17 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Also check to see that the vac hose is good to the vac operated valve.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-23-2013, 08:09 AM   #10
ab_70chevy
Ok, so both or my hoses are hot, both valves are opened as far as they will go, still no heat. Coolant level is to the top, and no kinks in the vacuum tube. Cables seem fine. Am I down to the heater core? Is there anything I can do to test it before I start ripping the dash apart to get to it?
Thanks again fellas-Andrew
Old 10-23-2013, 09:54 AM   #11
cdowns
cdowns's Avatar
lots of times the housing that the heater core is in is clogged with 40years of crap and no air can flow accross the heater core causing no heat// remove blower moter and stick hand in hole and start by pulling out quite a few handfulls of really really disgusting stuff tjen with air or garden hose start flushing the rest
Old 10-23-2013, 09:57 AM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
It's starting to sound like a plugged heater core BUT if it's plugged, coolant wouldn't flow. Since both heater hoses are hot, coolant must be flowing through them. The hoses should get too hot to comfortably touch for the heater to work well. If they're not hot enough you may have a bad (or wrong, or missing) thermostat, or restricted flow (possibly caused by a partially plugged heater core).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 10-23-2013, 10:04 AM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Don't forget to clean the mouse nests out of your heater box...... That will probably cure your problem.
You have to tear it apart to do that, or at least pull the blower motor like Cliff said. I use a vacuum to clean the "Stuff" out of it instead of my hands though...
LockDoc
Leon
Old 10-23-2013, 10:08 AM   #14
mrein3
mrein3's Avatar
You have to tear it apart to do that.
LockDoc
Either 40 years of leaves or a few days with a mouse will give you both heater hoses hot and no heat.
Plan a day to pull the box your heater core is in. Have Lysol and/or bleach handy in case its a mouse. If its leaves, get some screen material to put between your cowl panel and the opening under there.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-23-2013, 10:44 AM   #15
slikside
slikside's Avatar
Just a plugged core prolly wouldn't cause this, but a leaking one certainly would. That's what I had. The fluid leaks into the plenum carrying the odors right into the cab.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 10-23-2013, 11:32 AM   #16
cdowns
cdowns's Avatar
a heater core clogged with crap allows no flow of hot air as in no heat inside the cab of the truck/// and it is far more common cause of no heat than a ruptured leaking heater core
Old 10-23-2013, 12:51 PM   #17
ab_70chevy
I have been driving around for a couple weeks with out a cowl panel, while I'm gettijg it ready for paint. Think that could be an issue?
Old 10-23-2013, 07:00 PM   #18
Avitech
Avitech's Avatar
I just cleaned a mouse nest out of mine. That blocked almost all the heat and most of the airflow too.
1990 Suburban Silverado
350, SM465 and 35" tires
Avitech is offline   Reply With Quote
Old 10-28-2013, 10:05 AM   #19
ab_70chevy
Ok, so is replacing the heater core on and A/C truck the same as a non A/C truck? Iv never done one, so I really have no idea.
Old 10-28-2013, 10:08 AM   #20
ab_70chevy
Also, do I need to take off the inner fender to do it? It looks as if I can't get to all the bolts.
Old 10-28-2013, 10:09 AM   #21
LockDoc
LockDoc's Avatar
I don't think so. The heater core on an AC truck is in the inside heater box and the non AC is in the outside heater box.
LockDoc
Leon
Old 10-28-2013, 10:17 AM   #22
LockDoc
LockDoc's Avatar
Read this old thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=223703
Read all the way through because some of it is for non AC units....
LockDoc
Leon
Old 10-28-2013, 10:35 AM   #23
cdowns
cdowns's Avatar
how did you jump right to replacing the heater core???
from your initial post it sounds as if you have an air flow only problem and your heat solution is an easy no cost time only fix and you seem to b determined to try and throw money away by takin bad leaky advise????
is coolant level droping ?? smell of antifreeze?? a noticable leak at the core?? i did not see any of them symptoms listed????
