Th350 playying nice with ls swap
How did you guys run the kick down cable on your TH350 so it can downshift when you hit the throttle. I am using a cable drive not dbw. Pics or a description would be nice. It sucks having to manually downshift.
Re: Th350 playying nice with ls swap
No one?
I'm trying to figure this one out myself. Haven't quite finished getting the transmission back in. One option I'm considering is to attach the kickdown cable to the gas pedal; I did a similar thing on a Dodge Dart with an EFI slant six.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
Can you use the 71-72 electric kickdown for a th400? It is pedal mounted.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
![]() Join Date: Jan 2009
Try TVmadeEZ.com. It's bow tie overdrives site for their kit. To to the LS1 section. I had a friend that used it for a 700r4. Maybe it'll work for your application?
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
Interesting kit, but it appears to be for the car manifold instead of the truck intake.
The TV part does not look like it will work. Great for a 700r though.
Truck and auto performance nut
I ran a carb for a while with a 200-4r. Just hooked up the TV cable using a TCI adapter made for the job. Did you check http://www.hotrodlane.cc/
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
