Old 10-23-2013, 06:27 PM   #1
Gapp
Gapp's Avatar
Gapp's 64 project
Not very good at typing on the tablet so im gonna post a bunch of pics! I will try to keep them in order as it was done.
Gapp is offline   Reply With Quote
Old 10-23-2013, 06:48 PM   #2
Gapp
Gapp's Avatar
Re: Gapp's 64 project
Cpp brake booster/prop valve combo
Filling in some holes
Looking rough
[url=http://postimage.org/]
Haywire harness and fuse block. That was fun
Old 10-23-2013, 06:57 PM   #3
Gapp
Gapp's Avatar
Rear notch
Building the bed floor up with square tubing to clear the rear end
Pretty close...
Old 10-23-2013, 07:08 PM   #4
Gapp
Gapp's Avatar
Framed up
Just about ready for flooring
Old 10-23-2013, 07:14 PM   #5
Gapp
Gapp's Avatar
Aluminum planks going in.
Old 10-23-2013, 07:30 PM   #6
NEWFISHER
NEWFISHER's Avatar
Nice work!
NEWFISHER is offline   Reply With Quote
Old 10-23-2013, 08:18 PM   #7
Ta2Don
Ta2Don's Avatar
and welcome aboard...
Good looking truck, I'm in to watch your progress!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 10-23-2013, 08:25 PM   #8
1963c-10
1963c-10's Avatar
very nicely done. looks good and that flooring will last a lifetime pretty maintenance free
1964 Short bed trailer
Old 10-23-2013, 08:32 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
Hi and welcome! Nice build you have there!
Old 10-23-2013, 10:08 PM   #10
Gapp
Gapp's Avatar
Viair 480c mounted outside of passenger frame rail.
Little 2 gal tank on drivers side.
Before dropped spindles
After
Old 10-23-2013, 10:10 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Looks awesome! Like the drop!
Old 10-23-2013, 10:16 PM   #12
Gapp
Gapp's Avatar
Finally some new shoes. Completely changes the look.
Old 10-23-2013, 10:18 PM   #13
TJ's Chevy
TJ's Chevy's Avatar
Awesome! You take great pictures!
Old 10-23-2013, 10:25 PM   #14
Gapp
Gapp's Avatar
Thanks man! Hard to take a bad picture of these trucks!
Old 10-23-2013, 10:33 PM   #15
Ta2Don
Ta2Don's Avatar
Love the Stance!
DON
Proverbs 27:17
Old 10-23-2013, 11:06 PM   #16
wjjeeper
wjjeeper's Avatar
Looks awesome.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 10-24-2013, 09:45 AM   #17
kieth
kieth's Avatar
GREAT LOOKING TRUCK, IT IS REALLY COMING ALONG. DID YOU GET THE STADIUM SEATING PLANKS NEW, OR WERE THEY USED FROM A STADIUM TEARDOWN. IF THEY WERE USED WHERE CAN WE GET SOME OF THEM ? THANKS, KIETH
kieth is offline   Reply With Quote
Old 10-24-2013, 10:29 AM   #18
jdoisher
jdoisher's Avatar
Truck looks good!! And your close to me!!
Jason
http://67-72chevytrucks.com/vboard/s...d.php?t=531177
Maggie's truck!
jdoisher is offline   Reply With Quote
Old 10-24-2013, 12:12 PM   #19
sandiego65
sandiego65's Avatar
Your truck looks sweet man! How is your front suspension set up and what size drop blocks do you have in the rear and also what size are your white walls? Do your tires rub the front inner fender wells? I'm doing the suspension on my truck now and would like to end up with your drop are those pics at fully aired out?
sandiego65 is offline   Reply With Quote
Old 10-24-2013, 12:14 PM   #20
sandiego65
sandiego65's Avatar
That's a really cool way you repurposed those stadium seats.
Old 10-24-2013, 12:16 PM   #21
dr69burb
dr69burb's Avatar
nice truck man. whats the stats on wheels and tires?
Baggin 64 lwb project
http://67-72chevytrucks.com/vboard/s...d.php?t=537406
dr69burb is offline   Reply With Quote
Old 10-24-2013, 12:39 PM   #22
Gapp
Gapp's Avatar
Thanks! Sorry I never did post up build specs and whatnot. So here's the skinny:
Rebuilt 283
350 tranny floor shift w/ shift kit
Ramhorn manifold w custom bent exhaust and flow master single chamber mufflers
76 front end w disc
Dominator 2600# bags from AVS
manual valves
Viair 480c compressor
2.5" Dropped spindles
C notch w 2" dropblocks with custom front and rear shock mounts
15x8 rear steelies, 15x7 front steelies with Hankook h724 215/75/15 whitewalls all around.
Haywire complete wiring kit
cpp brake booster w prop valve
Bleacher planks were given to me by a buddy tearing down an old school stadium. They came in 20' lengths.
Had to trim the wheel wells in the rear to accommodate tires.
Shaved tailgate chains and holes.
New windshield
Pics are with truck aired out. The front tires lightly touch inner fender wells in front only.
LCAs almost touch the ground aired out.
I normally ride w 55-60 psi front, 35-40 rear and it rides nice
Old 10-24-2013, 01:56 PM   #23
sandiego65
sandiego65's Avatar
Sweet set up, thanks for the info are your lower control arms cupped?
Old 10-24-2013, 02:25 PM   #24
Gapp
Gapp's Avatar
Thank you! I decided not to cup the lca's. May end up going with some Strong arms in the future.
Old 10-25-2013, 01:54 PM   #25
timmytimm3
Nice truck! You should look into Porterbuilt's forward arms too. Solves a lot of common issues.
http://67-72chevytrucks.com/vboard/s...d.php?t=537266
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
