Old 10-23-2013, 11:08 PM   #1
muckyp
muckyp's Avatar
Front suspension differences
How can I tell what year model the front suspension on my truck came from. It's a 70 model C10 with five lug front and rear suspension parts. I would like to get some dropped spindles but I'm not sure whether to order spindles for 1972 or 1973.
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 10-23-2013, 11:16 PM   #2
Sklptrljay
Sklptrljay's Avatar
Re: Front suspension differences
Not 100% sure of how to tell since it's already been switched to 5 lug. I know the motor mounts changed to a "clamshell" style in 73, that's if you think the crossmember has been changed.
Sklptrljay is offline   Reply With Quote
Old 10-24-2013, 07:11 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Steel control arm bushings were used on 71-72. Rubber on 73-87.
If you ball joints are original with the uppers being riveted in, that is a definitive way to tell. If they've been changed, it could be anything since 71-72 and 73-87 ball joints will interchange.
Tx Firefighter is offline   Reply With Quote
Old 10-24-2013, 09:14 AM   #4
bbcmudtruck
I just went through all this! See if this helps you.
http://67-72chevytrucks.com/vboard/s...d.php?t=597723
bbcmudtruck is offline   Reply With Quote
Old 10-24-2013, 09:35 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
The upper ball joint or outer tie rod will tell you what year spindle is on your truck now.
Keith
Convert to disc brakes.
