Old 10-24-2013, 02:41 PM   #1
Mater/10
Mater/10's Avatar
2wd to modern 4wd ?
im doing a whole modern drive train in my 84' gmc and was wondering how hard it would on a scale of 1-10 on converting it to a straight axle up front im running a 5.3ls.
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline   Reply With Quote
Old 10-24-2013, 03:37 PM   #2
obijuan
Re: 2wd to modern 4wd ?
about a 3.
its all relative.
obijuan is offline   Reply With Quote
Old 10-25-2013, 02:04 AM   #3
andrewmp6
Its not hard just a lot of time and parts,I would skip the swap and buy a 4x4 truck to start with.
Old 10-26-2013, 06:52 PM   #4
LONGHAIR
Conversion is just that, adding 4 wheel drive to something that was not originally available that way.
Buy a 4x4 truck, then do your engine swap.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-27-2013, 07:32 AM   #5
350TacoZilla
the 4x4 swap on these trucks consists of unbolting the 2wd parts, adding the 4wd mounts up front and putting in a 4wd trans and transfer case. I have personally done the swap in 1 day with 1 other helper, on a scale of 1-10 I say 3 if 1 is changing spark plugs. If you are going 4x4 now is also a good time to go with 52" spring mounts up front along with poly bushings and good shackles. I suggest getting all your parts in order ahead of time and since truck is 2wd you can basically go straight for cross over steering if the axle you are swapping in can accept it.
350TacoZilla is offline   Reply With Quote
Old 10-27-2013, 01:08 PM   #6
obijuan
been down the 52 front springs road and i went back to standard 47s.
if youve got the motor out, all you gotta do is a motor crossmember and bolt in spring hangers. it really is very easy.
starting with a 4x4 truck to me is a waste of money because they are wildly overpriced.
what most dont mention is the rear spring hangers are also lower for a 2wd, swap those out too or just get taller lift springs.
Old 10-29-2013, 02:06 PM   #7
Mater/10
Mater/10's Avatar
I agree on the over pricing and thanks guys! So as far as a parts list? Correct me if anything else is needed.
1. Front Axle
2.Transfer Case
3. Springs/shackles/bushings
4. mounts
5. 4x4 engine cross member
6. Drive shaft.
Old 10-29-2013, 02:07 PM   #8
Mater/10
Mater/10's Avatar
Update on my truck : Lost the camper an grill guard. prepping for the 4x4 swap as wel as sbc.
Old 10-29-2013, 11:31 PM   #9
350TacoZilla
looks like you got the basics down, it depends on height you are going for also. shocks and brake lines if lifting truck (though 2wd rubber lines are little longer than stock 4x4 so if only going small lift you can retain them.)
Old 10-30-2013, 12:49 AM   #10
andrewmp6
The trans tunnel in the cab is taller on a 4x4 truck.
Old 10-30-2013, 01:56 PM   #11
350TacoZilla
yeah the hump is little taller and removable on 4x4 cabs, I have only had interference with the sm465/np205 combo.
Old 11-07-2013, 04:47 PM   #12
Mater/10
Mater/10's Avatar
i bought a 87' k20 ! for 720$ runnin an drivin so were on track now thanks guys!
Old 11-07-2013, 09:45 PM   #13
swamp rat
swamp rat's Avatar
Time for a build thread?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-08-2013, 01:16 PM   #14
Mater/10
Mater/10's Avatar
i will start a good Build thread with lots of pics Sunday or Monday!
Old 11-08-2013, 05:21 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
not all are removable
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-09-2013, 11:00 AM   #16
LONGHAIR
Why would you need to do a build thread?.......Now you have a 4x4 truck.
