Closed Thread
Old 10-24-2013, 11:06 PM   #8701
Formanbob
Re: What did you do to your truck today?
Put me motor back in
Formanbob is offline
Old 10-24-2013, 11:23 PM   #8702
mud.man.rj
mud.man.rj's Avatar
Looks like a pirate chest, cool.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 10-25-2013, 01:15 AM   #8703
Softpatch
Softpatch's Avatar
ttttt
Softpatch is offline
Old 10-25-2013, 01:16 AM   #8704
Softpatch
Softpatch's Avatar
I went and registered truck with Vintage plate sorry can't show the plates
the gal at the auto licence place said not for hauling could get ticketed ..WHAT.?
Old 10-25-2013, 12:19 PM   #8705
LVPhotos
LVPhotos's Avatar
Dragged this to buddy's house. Applied GM engine decals and test fitted the new Porterbuilt mount and bar.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 10-25-2013, 04:16 PM   #8706
Mike K
Mike K's Avatar
I just got power steering installed on my '66 with a 250 6 cylinder, but I used a used pump, so this weekend I hope to replace that pump with a new one. Hopefully, that will correct the issue of not having power steering at idle.
66 Chevy C-10 SWB, 250-L6, 3-speed manual OD
Mike K is offline
Old 10-25-2013, 06:56 PM   #8707
Chevymann66
Chevymann66's Avatar
Thanks man! I dig it too. Something different. Finished up the axle cover too.
---1964 C-10 SBW -Short Bed-
---1966 C-10--350 V8-4 Spd-BBW-Short Bed- SOLD!
---1964 C-10 :283 V8 -BBW Long Bed
Chevymann66 is offline
Old 10-25-2013, 07:00 PM   #8708
earl84
Originally Posted by luvbowties View Post
Man, what a deal. Remember: It's easy to forget to verify that your water pump will now turn backwards; keep this in mind when installing the serp. system, as you'll need to get the reverse spinning pump. Sorry to sound as if I'm talking to a newbie, but I've seen it happen to even highly-experienced mechanics.
Again, you scored big time, and I'd bet the components will happily surprise you as well!
Sam
I am a noob, so thanks for the heads up. From what I understand, a reverse pump will have a smooth pulley. But if I am reusing pulleys, how do I know that the pump I buy will be reverse pump? I guess when I get to that point, the parts computer at the store will tell me hopefully. Months away, though.
earl84 is offline
Old 10-25-2013, 07:34 PM   #8709
NEWFISHER
NEWFISHER's Avatar
Finished assembling the bed after Line-X'ing the inside panels and the wood boards separate. Still need to drill out the tubs and carriage bolt them down
NEWFISHER is offline
Old 10-25-2013, 09:23 PM   #8710
1963c-10
1963c-10's Avatar
Nice truck Softpatch...cant go wrong with a glenwood green 63.
1964 Short bed trailer
1963c-10 is offline
Old 10-26-2013, 12:45 AM   #8711
johnlq6975
I built myself a 60 by 80 shop this summer and tomorrow I go pick up my first projects . I bought a 62 step side today and I pick up my 62 fleet side from my fatherinlaw tomorrow and bring them home for a double build with my dad and fatherinlaw both of them r named Wayne and r 73 years old and r ready to work one will b totally stock as original as we can get and the other tricked to max I'm ready to get greasy
johnlq6975 is offline
Old 10-26-2013, 02:54 AM   #8712
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum. Sounds like you guys have a lot of fun work in the near future. Post up some pictures of the trucks and the shop when you get a chance. Good luck!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 10-26-2013, 09:48 AM   #8713
jbgroby
jbgroby's Avatar
Arranged the bed for transport to the painter for tomorrow!!!!!!!!!!! Last part to be done guys!!!!!
jbgroby is offline
Old 10-26-2013, 03:14 PM   #8714
rcg66
rcg66's Avatar
Not so much what I did today, but over the summer. With colder weather moving in, I am pretty much done working on my truck for the year. I have managed to get quite a lot accomplished though and am pretty psyched to think that by next summer I should be driving it. I have all new brakes plumbed and added a new booster and master cylinder. I installed a new intake and carb and fired up the 350 for the first time. I was like a little kid at Christmas when I heard it come to life for the first time. (Really loud though with only the exhaust manifolds)! I have all the wiring fixed and all the lights and gauges work. I installed a new aluminum radiator, as well as new u-joints and a carrier bearing.
rcg66 is offline
Old 10-26-2013, 05:23 PM   #8715
luvbowties
luvbowties's Avatar
Wink Re: What did you do to your truck today?
If I owned it, with that under-hood being such a BEAUTY and it not drivable yet, I'd get a friend to come lock down my hood and hide my keys--to keep me from being tempted to drive it ANYHOW! Nice work, rcg66.
Sam
luvbowties is offline
Old 10-26-2013, 05:29 PM   #8716
mud.man.rj
mud.man.rj's Avatar
I would drive it.
5.0 4spd std.
7" lift w 35's.
Old 10-27-2013, 06:26 PM   #8717
endlessearth
endlessearth's Avatar
It must have jumped in the bed when I wasn't looking. Can I keep it?
endlessearth is offline
Old 10-27-2013, 06:28 PM   #8718
ACK
ACK's Avatar
Did the headlight relay upgrade today. Found some real nice relays along with a metal bar designed to hold up to 4 relays at Junkyard Barbie. Used threaded rivets to install a good portion of the items, pretty nice tool.
My truck ain't dead, it just smells funny.
ACK is offline
Old 10-27-2013, 09:14 PM   #8719
65Gregg
65Gregg's Avatar
Put my gauge panel together when I got it back from the powder coater
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 10-27-2013, 10:14 PM   #8720
Lugnutz65
Lugnutz65's Avatar
This is what I did FOR my truck today.
I scored an unbelievable deal on some old school aluminum slots. I can't wait to see them after I polish them. Here's a sample area.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 10-27-2013, 10:20 PM   #8721
A.T. RockDriller
A.T. RockDriller's Avatar
And is that a 50/60 series COE grill yer holdin out on us there...maybe...?
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline
Old 10-27-2013, 10:22 PM   #8722
Lugnutz65
Lugnutz65's Avatar
Originally Posted by A.T. RockDriller View Post
And is that a 60 series COE grill yer holdin out on us there...?
Yes indeed. Right off of a bus. Needs a good sanding or better yet -sandblasting. I also scored an UNBELIEVABLE GMC hood. Wanna see? More pics of the shopping trip on my website - see signature.
Old 10-27-2013, 10:47 PM   #8723
hopped up
hopped up's Avatar
That's a great score! Can't wait to see them polished up. I'd like some six lug slots
hopped up is offline
Old 10-27-2013, 10:48 PM   #8724
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Just ordered some stuff from LMC Truck‏ to add to the suicide doors.
1 38-9175 DOOR BOTTOM INNER-RH
1 38-9172 DOOR SKIN-LH 31" HIGH
1 38-9174 DOOR BOTTOM INNER-LH
1 38-9173 DOOR SKIN-RH 31" HIGH
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 10-27-2013, 11:14 PM   #8725
bloody hammer
bloody hammer's Avatar
pulled the clutch, smashed a finger.
bloody hammer is offline
Closed Thread
