Old 10-25-2013, 09:29 AM   #1
68basket
4l60e transmission fluid?
I am about to fire up my 5.3 and 4l60e and need to buy trans fluid. I found the spec shows dex vi. Is this correct? any preferences on what trans fluid you are using?
68basket is offline   Reply With Quote
Old 10-25-2013, 09:41 AM   #2
solidaxel
solidaxel's Avatar
Re: 4l60e transmission fluid?
How many qts. will it take?
Did you remove the pan?
Are you changing the filter?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-25-2013, 09:44 AM   #3
68basket
has no fluid at all in it. I had to spread it apart to change the tailshaft from 4x4 to 2wd. so this is an all new fill probably 11 qt
Old 10-25-2013, 10:23 AM   #4
truckdude239
truckdude239's Avatar
Did you drain the convertor? If not should hold around 4-6 qt if the convetor was drained too around 11-13 qts
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-25-2013, 10:49 AM   #5
68basket
yes, drained the converter and new filter, all new gaskets. Just wanting to check to make sure the dex vi is the correct/best fluid for this trans?
Old 10-25-2013, 02:28 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Dex VI is just the current name for Dexron.
Anything after Dex III should work, but iirc Dex VI is just the current iteration. If you would have looked up that same info 4 years ago, it would have said "use Dex III", then IV, then on and on.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
