Old 10-24-2013, 11:13 PM   #1
Dm1pfoy1
Dm1pfoy1's Avatar
Question Another timing question.
I have 383 with stock 350 heads 625 cfm demon carb 204/ 214 or 224 ? @ .050, .420"-.442" 112 lsa cam with TH350 and power brakes.So I have timing set to 0* with vac line pulled as of right now my timing markers only go to 14 or 16* advance and I am not going to worm my way in there to some how mount a wider degree marker to block. I am pulling 12*-14* on vac advance from what I can tell. So from what I read 36* total time is what I need. That would put me 24*-22* idle timing. Since my markers dont go high enough and I don't want to ruin my engine how should I time vehicle?
Vac timing comes to mind @0* I am right about 10-12 lbs of vac. I am unsure how to vacuum time a vehicle. I want to get this right and I am assuming all other fuel portions are within tune what options are there or how do I time it?
Project Fast 'n' Loud
72' C10 SWB Fleet, Faux Patina, 383 ci stroker
The Page: http://67-72chevytrucks.com/vboard/s...d.php?t=608214
Dm1pfoy1 is offline   Reply With Quote
Old 10-24-2013, 11:21 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Another timing question.
Get a timing light with an advance dial on it and use the 0° mark.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 10-25-2013, 12:38 AM   #3
Dm1pfoy1
Dm1pfoy1's Avatar
I don't have the extra cash to get another light from what I see they are bout $100 just dont have that to drop right now but I appreciate info didn't think of that but just can't afford it. Is there any other options?
Old 10-25-2013, 01:05 AM   #4
zeldman
zeldman's Avatar
Do it the redneck way then.... that is keep advancing, test drive and when you get detonation, back off a little. Or at least use a vacuum guage.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 10-25-2013, 10:50 AM   #5
Longhorn 70
How about timing tape?
Just get under the truck.
Clean the balancer and measure the balancer diameter.
You can stick something like THIS on it.
