Old 10-23-2013, 03:04 PM   #1
boynton
boynton's Avatar
fuel gauge issue
Ok so I have been chasing wiring gremlins in my truck for a while and have almost all of them worked out. One I need help with is my fuel gauge. As far as I know the only two wires that control your fuel gauge are the brown wire from the tank that runs from the tank to the fuse block and then to the gauge cluster and the other wire is a ground. I am thinking that my gauge harness may have an issue. Is there a way to wire strait from the tank to the gauge? I am using stock gauges. I tried this and the fuel gaige just went well past full and stayed there even when on empty. I thought that I may have a bad gauge, so I tried another gauge that I had that I know works and same result. Any ideas?
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 10-23-2013, 06:35 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: fuel gauge issue
Usually when you loose ground to the sending unit or the gauge it causes the gauge to read past full. When it is a power issue, it stays on empty.
You can run a wire right from the sender to the gauge. I would put a 10 amp in line fuse in the wire just to be safe. Make sure you have good ground on the sender and good ground on the gauge side. The ground on the gauge is the terminal towards the right when looking at the gauge cluster from the back side. It shares ground with the brake and temp warning lights.
You did not mention what your exact problem is. Does your gauge read past full or on empty? Maybe I misunderstand your post.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 10-24-2013, 03:30 AM   #3
boynton
boynton's Avatar
Oh no you read it correctly and have answered my question perfectly. I think this is there exact information I need to get it going. Thank you. Ill try it tomorrow or Friday and report back.
1970 SWB Step-Side
Old 10-24-2013, 09:13 AM   #4
luvbowties
luvbowties's Avatar
Question Re: fuel gauge issue
I also think you should double-check that part where it was said "the brown wire from the tank that runs from the tank to the fuse block and then to the gauge cluster and the other wire is a ground". You may find there is no hot wire going to the tank, but only additional grounding from gauge to tank.
Sam
luvbowties is offline   Reply With Quote
Old 10-24-2013, 09:21 AM   #5
GMC Canuck
An open circuit in the sensor circuit will cause the gauge to read way past full.
Take the wire off the sender and touch it to ground, this should make the gauge read empty. If you touch it to the tank, this will prove a good tank ground as well. If the gauge responds, problem is the tank sending unit, if not problem is wiring to the tank. You can ground the terminal where it comes out of the fuse block and that will isolate which part of the circuit you need to chase.
GMC Canuck is offline   Reply With Quote
Old 10-25-2013, 02:05 PM   #6
boynton
boynton's Avatar
well it turns out it is the sending unit...there goes another $50 haha I was hoping just a little time and effort and maybe some extra wire would solve the issue
1970 SWB Step-Side
Old 10-25-2013, 02:07 PM   #7
GMC Canuck
Thanks for the update. It's always good to hear the solution to the problem.
Old 10-25-2013, 02:10 PM   #8
boynton
boynton's Avatar
Thanks for all of the help. It is simple things like this that I am unsure how to trouble shoot and great board members have continued to come to the rescue for me! Thank you to all of the wiser and more knowledgeable members that help out!
1970 SWB Step-Side
Old 10-25-2013, 02:13 PM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
Great, glad to hear you got it figured out.
