More Tow Hook ???s
On my 72 K20 during frame painting I noticed that it was drilled for hooks so I searched for an original set and I just got them the other day and have attached a few pics of them installed. I can barely see a part number for the left or right side but it looks to be 3941733-4 or 3941732-4 but it is not clear enough to be sure. Does anyone have the numbers for left and right side? The other questions I have are about the install. If you look at how I have them, I am not too sure which direction the tips should go and also the plate that is spot welded on to the forward spring perch is there on one side and missing from the other. The welded on plate interferes with the hook on the left side (seen from the drivers seat) and it doesn't seem to make a difference which hook I put on that side (hook tip pointing in or out) there isn't enough clearance to get a strap on there. The first pic is left side with tip pointing out (missing plate on perch) and the clearance is the second pic. The third pic is the left side with the perch plate and tip pointing out and (lack) of clearance. The rest are of the hooks reversed tips pointing in. I think what I will do is to remove the welded on plate on the left and point the tips out, but I was curious if this is what the extreme bend hooks were all about (getting around the perch plates). Any info would be much appreciated and probably make my whole day. Big Enjoys!
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
Re: More Tow Hook ???s
sorry first pic is of the RIGHT side with the missing perch plate....
I will try and dig on a pic of mine when i get home later tonight. I believe the hooks point out tho.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Flip em side for side. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
First, let me say I'm not the guy that knows the correct placement of hooks on these trucks. That being said, I don't think they are wrong I would say the turn should point inboard. You definitely don't want to turn them around. Hooks out is asking for trouble by putting the weak side to the load. To me they look fine. As far as clearance for straps, I don't know what size of straps you are planning to use but from the pics, all of my rigging I carry on my 4 Runner would fit fine and I have nothing rated for less than 10K (most of my endless straps are 20k) since that's what my winch can straight pull. You should only need 1/2" clearance between the frame and points to get most strap eyes in there. Another option which I would recommend if you do actually use them for recovery is to use a shackle, 6 ton or better is what I carry. As far as recovery supplies, I highly recommend grabbing an ARB recovery bag since it comes with everything you need to properly recover or yank on just about anything short of a tank. They do look like beefy hooks, a lot better than what is going on trucks nowadays. I would also recommend adding some plate stock material on the inside under the nuts for extra stiffening. I wish I had a nickle for every late model Chevy tow hook I've seen broke due to what I see as cheap material and being cast not forged.
Owner: Times Are Tough Toys 92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Wrecked 71 Chevy K20, Clifford, BB and 1 Tons |
swamp rat, thanks I appreciate any effort with my puzzle.
Trevor, when you say flip them side for side what do you mean? I included pics of them with tips to the outside and also inside. Which still leaves no clearance on the left for a tow strap. I for sure will never run them with the hook open toward the front, I have pulled too many people out (and been pulled out myself) to try that. ![]() Premature, thanks, always good info on who uses what for heavy duty recovery. I have two bags I carry for tow straps, clevises, hooks and tie downs, it's nice to have options when the going gets tough and I also tow a trailer occasionally so choices are needed there too. Mistakes or equipment failure during recovery is never good. If you look at the third and fourth picture you can see that there is NO clearance to put a strap on the hook. The pictures are not of the permanent install, I plan on blasting them and powder coating and I agree they need extra reinforcement on the inside of the frame for really heavy loads.
I'm ignorant on the factory tow hooks. I thought I read in another thread that '72 hooks had the large bend to avoid the spring mount
#8 | |
![]() Join Date: Sep 2010
I have a 71 truck with 72 tow hooks. OC - let me know if you want to discuss a swap. |
There were two types of hooks available in 72. The "left and right" hooks with a small bend and then the extreme bend that had the bend going the same direction. Searching this forum I found the part numbers for the 69-72 and the 72 only extreme bend and it looks like they all had the same numbers.
1. Quote: Originally Posted by jc #s from my book are as follows 1967-1968 style are 3663349 (RH) ------------------------3663350 (LH) 1969-1972 style are 3941733 (LH) ------------------------3941734 (RH)
Here's pic's of mine, looks like your not alone...
![]() Side note: See all that green stuff, thats where my handle came from, the truck was covered in it foir a while... LOL!
Swamp Rat: Hey thanks very much that info is most helpful. I see that you also have a plate spot welded on the drive side spring perch and NOT on the passenger side. If the plate was not there on the left everything would be puppy dogs and rainbows! I will most likely remove my plate but now I am wondering what that is all about. After searching this subject in the forum it seems that is the way these trucks are delivered. I thought I had knocked the plate off during some too happy four wheeling but it looks to be a factory feature. Any thoughts as to why one side and not the other? Thanks again and good handle...
#12 | |
It's purpose was explaned in this thread
My 71 has the plate welded on the driver side spring mount. I was think of cutting it off when I start working on the frame. wondering if it was installed for a reason.
Wow that is amazing....this really is such a valuable resource for our brand. That is really something that someone has already answered that, thanks a bunch... mystery solved and I will NOT be removing that plate.
#15 |
Roadtrip!
![]() Join Date: Feb 2003
There should also be a bracket on the frame behind the drivers side leaf spring so it can't go back too far.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#16 | |
I guess as long as you can loop a chain or strap thru the hook then why bother and make your truck unsafe. Thanks for posting the thread and link, mucho appreciated! ![]()
#17 |
Yes i have one there too and was wondering why it was there.
#18 |
Currently Blazerless
The problem was with the factory springs breaking up near the spring eye. I drove a truck home about 75 miles that had that same break with no problems because of that plate and rear stop. If your using aftermarket springs you can do away with them, if you still have the factory springs it would be a good idea to leave them.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#19 |
I have a 2" soft ride spring set but I did use the old bolts. They were surprisingly clean for being over 40. I think I'll replace the bolts to be sure, I like the greaseable ones Swamp Rat has in the pic above. I think if I replace the bolt I will be more acceptable to removing that plate and that solves my problem of trying to find a set of extreme bend hooks too. If I don't remove the plate that hook is basically unusable. It sounds like a few people were wondering what the heck that plate did so thanks again for the posts, this site rocks. I feel so much better about making an effort to get the hooks on to my 4X4. I have to admit I was a little disappointed when I first installed them and ran in to this issue. But now it is time for alcohols!!
#20 | |
I posted pic's in my build thread which admittedly as of late has become a frustration vent thread.. ![]()
#21 |
Swamp Rat, thanks again. I just got done reading your build post to find out what you had used for greasable bolts. Sometimes it is hard to find the motivation when you run in to problems. I try to imagine what it will be like driving down the road when everything is done and done the way I want it. I have changed direction a few times already to try to stay on track.
#22 |
Ha I just realized that you know what the Orange Crate was...ha...I thought I was the only one that was crazy about that bike as a kid. Now I'm crazy about a different Orange Crate....too cool.
#23 |
No problem, glad i could help..
