Old 10-12-2013, 11:56 PM   #1
Jimbabwe
Jimbabwe's Avatar
freakin' creakin'
When raising/lowering my truck airbags, the front makes slow creaking noises. What needs to be lubed/tightened?
Jimbabwe is offline   Reply With Quote
Old 10-13-2013, 12:19 AM   #2
67ctener
67ctener's Avatar
Re: freakin' creakin'
Not sure but bad ass step side
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 10-13-2013, 12:37 AM   #3
Jimbabwe
Jimbabwe's Avatar
Thank you, Sir!
Old 10-13-2013, 09:57 AM   #4
hellbent72
Are any of your bushings poly? A-arms, sway bar? Sweet truck by the way. Is the front end new, bushings and metal parts
hellbent72 is offline   Reply With Quote
Old 10-13-2013, 10:39 AM   #5
Jimbabwe
Jimbabwe's Avatar
Thanks Hellbent,
Everything is new. All of the Porterbuilt stuff front and rear was finished and I've been driving the truck on weekends since spring. The creaking is a relatively new development. Only my I6 motor mounts were loose at the motor ( and appear to be a real pain in the butt to get a wrench on). The PB control arm bushings are delrin and the sway arm appear to be rubber. No poly anywhere. I have gobs of grease oozing out of my ball joints no matter how many times I wipe them off, if that's not normal. No grease ports for control arm shafts, but you wouldn't lube delrin bushings anyway.
Old 10-24-2013, 02:24 AM   #6
66 C10 383
Global West has been making their Del-A-Lum bushings for 30 years and they all have grease fittings in them. The "Del" in the name stands for "delrin".
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 10-25-2013, 02:38 PM   #7
clapage6
most delrin will swell with any kind of grease or oil applied unless it's got a lot of teflon or nylon mixed in with it. I don't know specifics about either brand so who knows. but it sounds like dry sway bars bushings to me fwiw.
clapage6 is offline   Reply With Quote
Old 10-25-2013, 06:55 PM   #8
Jimbabwe
Jimbabwe's Avatar
What would you lube the sway bar bushings with? I have teflon based grease I use on my bikes, if that matters.
Old 10-25-2013, 07:14 PM   #9
clapage6
try and go with the thickest/stickiest stuff you can find, I've had good luck with "marine grease" that's all it said on my container of it but it seemed to last the longest for me. Sway bar bushings are a pain to keep greased especially if you don't have the greasable ones. rain etc washes em' dry. I don't know if there is anything specific that would cause rubber bushing to swell, I haven't noticed swelling on any factory or oe replacement rubber bushing with any of the grease i've ever used personally...
Old 10-26-2013, 02:44 AM   #10
66 C10 383
I have no idea what delrin Global West uses but I've used 2 sets of those bushings with one set almost 10 years and they are still as smooth as the day I put them in so they haven't swelled any.
I wish GW would make these for our stock a-arms, I'd buy a set in a heartbeat!!!
Hey Global ... hint hint hint ...
Doug
