Old 10-27-2013, 09:26 PM   #1
jrdecat
Loose Steering Column?
So I have an 89 Jimmy that had some loose steering. I wanted to fix it so I replaced all the tie rod ends and power steering gear. All the moving stuff in the front is new, so my question is: are there parts in the steering column that can wear out and cause slop? Or is it just normal with wide tires and a 4" lift to feel like you're sawing logs to keep it going straight. 32x11.50's btw.
jrdecat is offline   Reply With Quote
Old 10-27-2013, 09:39 PM   #2
esbstuff
Re: Loose Steering Column?
Loose steering linkage and big tires equals a truck (or jimmy) you can hold in the road. Most likely its not in the column, but could be steering box loose also. But before I spent $$$ on a rebuilt box, I would fix everything else and check the frame where the box mounts. With the bigger tires you should invest in a steering box brace kit like yesterday!
esbstuff is offline   Reply With Quote
Old 10-27-2013, 10:02 PM   #3
jrdecat
already put the steering box in and the frame looks good where the box is mounted. i was asking because i had already replaced everything that i thought could be the problem. i'll definitely look into the brace kit. looking to get rid of the wide tires and go with 33x9.50's for the winter time.
Old 10-27-2013, 10:35 PM   #4
Rascal_one2001
Rascal_one2001's Avatar
you can get sidewall flex running 15 inch rims and 33s. but every 4x4 solid axle I have had had issues with the front spring mounts flexing.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 10-27-2013, 11:46 PM   #5
Sodell
Sodell's Avatar
Might be a dumb question, but did you replace the Pitman and Idler arm?
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 10-28-2013, 03:38 AM   #6
83GMCK2500
No one has mentioned this little guy yet, but how's the rag joint?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
