Old 10-28-2013, 03:04 AM   #1
y5mgisi
Second Chance Program
y5mgisi's Avatar
How far off does camber halve to be to cause pull?
Im tryin g to figure out why my 78 (d44 front. all stock) pulls hard to the right. Its done it the whole time i have owned. I have checked the toe and it was dead even so i adjusted it to 1/8" toe in. Which made no difference. I also replaced the driver side ball joints which were very worn. THat also made no difference.
The truck pulls pretty hard. You have to keep a constant pressure on the wheel to keep it heading right. If you let go of the wheel, it doesn't quite "dart" to the right, but it goes right. And not just a slight slow drift. Somewhere between a dart, and a slow drift. MAybe call it a hard drift. Anyway, the front end seems to be in pretty good shape. The tires appear to be perfectly straight up and down with zero camber. Also the truck stops straight with no pull from the breaks.
So my main question really is, if my camber looks perfect, could it actually be bad enough to cause such a significant pull?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-28-2013, 06:52 AM   #2
Bigdav160
Bigdav160's Avatar
Re: How far off does camber halve to be to cause pull?
You need about a degree difference between right and left to cause a slight drift.
You would be able to see the difference. I'd switch tires left to right and see if your pull doesn't follow the tires
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-28-2013, 08:56 PM   #3
LONGHAIR
Swapping tires from one side to the other may not show you anything, but that does not necessarily mean that it is not a tire issue. I have seen specific tread patterns cause pulling/drifting.
I would also look into things like bent or broken springs and/or center pins. An axle housing that is shifted, even slightly, can cause this too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-28-2013, 09:21 PM   #4
BMERDOC
BMERDOC's Avatar
If I had it in my shop to diagnose I would check for a tire pull after confirming a good alignment.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-28-2013, 09:26 PM   #5
Special-Ed
Special-Ed's Avatar
swap the tires
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 10-29-2013, 08:43 PM   #6
y5mgisi
y5mgisi's Avatar
Ooops. how about this pertinent tid bit... It behaves the same way with all three different sets of wheels and tires i have had on it.
Old 10-29-2013, 08:46 PM   #7
y5mgisi
y5mgisi's Avatar
First set,
Second set,
Third set,
Old 10-29-2013, 08:52 PM   #8
y5mgisi
y5mgisi's Avatar
This is the only straight on shot i have of the truck. Hard to tell but the tires do LOOK dead nuts straight up and down. Obviously they probably arent perfect... But looks wise, they are very very close.
I should also add that just yesterday, i had the front end up in the air for something else, and i made sure and gave both tires a spin. They both spin freely. Or at least, equally freely. There is always going to be some resistance from the bearings and brakes, but give either side a spin and they keep going for about a full rotation.
Old 10-29-2013, 11:02 PM   #9
BMERDOC
BMERDOC's Avatar
Maybe its your steering box?
Nick Carter
Old 10-29-2013, 11:05 PM   #10
Special-Ed
Special-Ed's Avatar
after further review... id take the best tires you have, put them on, take it to a shop have them check the front end and balljoints then have the alignment verified and fixed....
iirc there was also some kind of issue with the geometry of the pitman and idler arms to the center link that created some kind of issues like this...
is it safe to assume you have checked the brakes and the bearing? air pressure?
Old 10-30-2013, 12:37 AM   #11
y5mgisi
y5mgisi's Avatar
Not going to say its not possible, but it just seems strange that I Just have to hold the wheel at about 20* to the left for it to go straight. If i let go of the wheel, the wheel returns to 0* and i start heading right.
I will have to do that. I have checked brakes, bearings, and pressure. In fact i have the left side a little lower than the right to help offset the pull.
Old 10-30-2013, 09:22 AM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
Measure your springs front and back both sides and see if the axle is centered. Camber doesn't really cause a pull directly but it can but you would have to have quite a bit on on side.
Castor if its off can cause a pull
Toe angle will cause a huge pull and that's prob you issue. Evidence of toe angle being wrong will be easy to find on the tread. Look at your tires edge inside and outside. If any of the tread blocks feather up or aren't flat like they should then its a toe angle issue
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-30-2013, 04:01 PM   #13
y5mgisi
y5mgisi's Avatar
I will have to check for the axle being evenly spaced on each side of the truck. The toe is good. When i first checked it it was exactly zero toe. I adjusted it an 1/8" in and it didn't change anything.
