Old 10-28-2013, 09:09 AM   #1
77ChevySharkBite
77ChevySharkBite's Avatar
Edelbrock Carb Help
I got a question for you guys anyone good with tuning a carburetor?
I need some help for sure. alright so I know I'm going from manual choke to electric so a few things are different but I know I don't have to pump the gas anymore or most of the time.
When it cranks up the idle shoots up to about 1,500rpm I usually let it sit there a couple of seconds and then tap the gas and it will idle down to around 500-750rpm, and I guess sometimes because it hasn't warmed up fully sometimes it'll die. Also if I let it just idle there for a little while say 5-7 minutes then I kill it, try to crank it back over it's like it doesn't fire right away but when it starts it's on all 8, is that just a way the electric choke works or do I need to do some tweaking? It runs and performs waaaay better just trying to start understanding it a little better.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 10-28-2013, 12:53 PM   #2
8lugnutz
8lugnutz's Avatar
Re: Edelbrock Carb Help
Mine did the same thing. One thing that I did notice on the old build was that one of my throttle return springs had fallen off, so I was only running on one spring. The accelerator would basically be on the floor and I'd either have to pull it back up with my toe or a quick tromp on the pedal to get it back to idle. Also, the throttle cable was a little sticky due to the PO twisting it to get it back on the linkage, so the cable was a little bit bigger (kind of like untwisting a rope, if that makes sense). I know there are two screws on the throttle linkage, one for idle and one for high idle, I had to bring up the idle. I'd check these few things first.
When I rebuilt mine last week, I put everything back exactly the way it was except hooking up the second spring and the straightening the cable back out and the it was sooo much better at idle. As far as the choke, you can loosen the three screws and rotate the choke to lean/richen the mix. Maybe it's too rich? I'm new to these carbs to, so I'd be interested in any other ideas.
1980 Chevy K10 Silverado --> Build Page
My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper.
8lugnutz is offline   Reply With Quote
Old 10-28-2013, 01:00 PM   #3
77ChevySharkBite
Yeah that's my belief is that it's getting too much fuel especially with a harder crank. I went and bought new return springs and everything. I even had to buy a shorter cable due to fact the old one was too long and needed one shorter cause it was so tight. It's still a tight but it's not where I have to mash it I do have to put a little effort into it.
I'm not too sure I want to mess with the choke just yet but I have a feeling that, that might solve the issue overall cause I know from a cold start it's going to take a little ump to get it going but from a warm start should crank and I'm thinking either it's not getting enough to make it an easy start or it's getting to much for a hard start.
Hopefully we can get our answer I know there's knowledge on here if I figure it out on my own I'll let you know.
Korwin
Old 10-28-2013, 02:08 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
With the engine cold, and on a cool day (not freezing cold)---The fall days are the best for this. With the air cleaner off of the carb, loosen the three screws on the choke housing and turn it back and forth, while doing this watch the choke butterflies and see what would make them start to move off of full open position. This should be close to where the choke should set itself and close for a cold start. Set the screws and work from there. When the choke is set, there is an idle screw on the drivers side of the carb (under the throttle shaft) adjust it to the RPM that you want the truck to run when it is cold. The adjustments from there can be made in small increments until you are happy. You do not want the choke plates to stay closed for a long time, that is where you get the rich smell from.
Frank
Old 10-28-2013, 02:11 PM   #5
77ChevySharkBite
Okay could that also be part of the problem of after letting it run for a good amount of time if the choke isn't open all the way cause the a harder warm start?
Korwin
Old 10-28-2013, 02:27 PM   #6
85/Silverado
85/Silverado's Avatar
Excuse me for butting in, but my Edelbrock Carb (size Unknown) Is doing the same thing I think, plus every time I shut off my truck it smells like a gas station just poured gas all over my truck. I can't find any leaks either, so Is that the choke closing after I turn off the key and draining fuel into the carb.?
85/Silverado is offline   Reply With Quote
Old 10-28-2013, 02:28 PM   #7
bnoon
Sounds like you've got two issues just as piecesparts says. Too much choke and too high of a on-choke idle. You may also want to use a vacuum gauge to set the off-choke mixture to ensure warm idle fuel (with no choke) is correct.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 10-28-2013, 02:31 PM   #8
bnoon
No fuel should drain from the carb at any time. If it does, you have a stuck float and/or leaks (internal leaks are harder to spot). The choke is only a metal flap that closes to restrict air going into the engine, it will not act on the fuel directly speaking.
Old 10-28-2013, 03:18 PM   #9
77ChevySharkBite
Well I just figured out an issue that I did that might fix all of my problems, I didn't put the right hose on the right vacuum so could that be causing issues?
Because my distributor vacuum isn;t connected to the right port, and my manifold vacuum isn't in the right port either, could that solve all my issues?
Along with the choke issue.
Korwin
Old 10-28-2013, 04:19 PM   #10
8lugnutz
8lugnutz's Avatar
Mine was flooding bad last week, and I ended up rebuilding the carb. It was ~$45 for the kit, and had it off, repaired, and back on in an hour or two.
Shark:
As far as vacuum lines, what do you have/how are they hooked up? Here is what mine looks like:
Passenger side goes to the distributor, driver side goes up to the deal above and to the left of the brake booster. Center goes over to the driver side valve cover, and the back orifice connects to the brake booster.
Since the rebuild mine runs better than it ever has!
Old 10-28-2013, 04:41 PM   #11
77ChevySharkBite
Originally Posted by 8lugnutz View Post
Shark:
Yeah I think I have my manifold vacuum connected to the timed vacuum port and the manifold vacuum port blocked off. So I pretty much just have it all switched up. When I started watching more youtube videos today from Edelbrock and the more I watched the more I realized I was missing something.
Korwin
Old 10-28-2013, 05:13 PM   #12
piecesparts
You do not have to connect the manifold vacuum to the ports on the carb to get vacuum to the distributor. The carb is the source of the vacuum to the dizzy, through orifices built into the carb body. You just have to pick either the timed port or the open port as to how fast you get vacuum to the dizzy dash pot. The adjustment of the idle screws using a vacuum gauge is the most efficient way of setting the fuel mixtures. When you connect the gauge, all you have to do is connect it to the intake manifold at a vacuum source and adjust the screws to get the right idle mixture and speed settings. My truck is connected to the open port and not the timed port due to my setup on my distributor springs and weights. If you are mostly stock, then the timed port is what you want. Cap off theother port if you are not using it for something.
The Edelbrock and the Carter AFB model carbs are EXACTLY the same carbs, with the same parts, just using different part numbers to make it look like they built them in different factories. Parts from one brand works in the other. They are built by a company called Magnetti-Marelli.
Set the idle first with the vacuum gauge and then wait for a cool evening or morning to get the choke spring to cool and set the choke plate for actuation when you push the throttle pedal down one time. Make sure that your electrical wire to the choke is on a ignition triggered power source, so that it starts to heat the choke spring when you turn the key on.
I set my idle speed, when it is on the choke about 1200 RPM and that is when it is on the high cam point of the choke rod cam. (the cam is on the driver's side of the carb down low and the idle speed screw sets against it) That way if it is not too cold, then it hits and idles at an RPM just a little lower than that.
If you have run your engine for a good amount of time and the electric wire to the carb is on at all times while the ignition is on, then the choke should be open. After you turn it off, it will take a while to start to go in the closed direction as the spring inside cools. If you do not push on the throttle or move the throttle in any way, after you turn the engine off, the choke plate will stay open due to the set screw sitting against the cam lobe on the side of the carb. When you push the throttle back, then the spring will snap the choke plate towards the closed direction.
Frank
Old 10-28-2013, 05:33 PM   #13
8lugnutz
8lugnutz's Avatar
Good info Frank, I probably need to tune mine a little better following your instructions above, mine seems awfully rich at idle. Thanks for taking the time to spell that out for us!
Old 10-28-2013, 05:42 PM   #14
77ChevySharkBite
Okay thanks pieceparts!
Well upon further and further reading and watching of youtube it seems to actually all be in the timing, being that I was basing it off the original way doesn't always work correctly so I'm going to be search either tonight or tomorrow whenever I have free time. I'm going to see about setting the timing to the correct timing.
The only bad thing about trying to do it on a cool morning is with Texas weather that's so unpredictable so it'll hard to be do it on a cool morning or evening.
Thank you everyone for all the help and advice you've given me I greatly appreciate it.
Korwin
Old 10-28-2013, 06:13 PM   #15
If you are not using the thicker insulator between the carb and the manifold, I have hear that will give you the hard starting issues when it is hot. WE did a couple trucks down here and they were fine until you tried to restart it hot. Once we put in the thicker isolator, problem went away.
Old 10-28-2013, 06:36 PM   #16
77ChevySharkBite
Thanks Palf70Step going to have to keep that in mind incase it continues once I get the timing set correctly.
Korwin
Old 10-28-2013, 09:55 PM   #17
77ChevySharkBite
So the truck is running beautifully and better than EVER!!! The PO apparently had no idea what they were doing it was ridiculous they were 1 tooth counterclockwise off and they were running at least 20 degrees advance is what we guess they also had scratched into the balancer what they thought might have been the correct line, so that's solved so the truck just loves sitting at 0 tdc so that's what we're going to stay with tomorrow if I can I'll get some test runs in
Korwin
Old 10-28-2013, 10:59 PM   #18
85/Silverado
I have the same carb as you (1406), How hard is it to rebuild? I'm a novice but I'm willing to try. I also need to do something about oil leaking out of the Intake Manifold bolts, They loosen up all the time which lets oil seep out onto the aluminum intake not bad but it looks like a mess all the time. So when I remove the Carb I would like to fix that at the same time. Is that Hard?
Old 10-28-2013, 11:10 PM   #19
77ChevySharkBite
I bought my carb brand new so no rebuild kit necessary but I would think a rebuild kit just follow the instructions ans use the recommended tools and you'll be fine. Concerning your issue with oil can you tell where it's coming from? My only real suggestion I can give you is replace your gaskets and use a sealer for the intake manifold and use cork gaskets for the valve covers if you swap those out too but that's the best advice I can give you.
Hops it helps
Korwin
Old 10-28-2013, 11:27 PM   #20
8lugnutz
8lugnutz's Avatar
Don't know if that question was for me, but It wasn't very difficult at all to rebuild. The rebuild kit was around ~$45 at O'Reilly's and had full instructions on tear down and rebuild.
As far as being a novice, don't worry about that. I had never rebuilt a carb before either, and I felt this was pretty easy. I did have my iPhone right there during tear down so I took lots of pictures to reference when putting back together if needed. For the fuel mixture screws: before removing them, actually count the number of turns to tighten them until snug, then remove then. When you reinstall them, tighten till snug, then back them off the same number of turns.
Old 10-28-2013, 11:55 PM   #21
geezer#99
geezer#99's Avatar
You got it set at 0*!!
Good indication your balancer has slipped or you set your timing with the advance hooked up.
Find true tdc #1 and see where your timing marks line up.
geezer#99 is online now   Reply With Quote
Old 10-29-2013, 12:53 AM   #22
piecesparts
You will want the timing advanced to more than "0". Something ain't right there.
Frank
Old 10-29-2013, 08:44 AM   #23
77ChevySharkBite
We also made sure that we had the advance unhooked and plugged to try and get the best accurate reading possible.
We tried going to 8 degrees and the truck just wouldn't have it, it was too much advance for it that it wanted to die.
it's not sitting at 0 tdc I wrote that wrong it's sitting at 0 degrees btdc I'm sorry i just saw my error in my writing.
Korwin
Old 10-29-2013, 10:44 AM   #24
geezer#99
geezer#99's Avatar
Guess what!!
0* tdc or 0* btdc is still zero.
Which way did you turn the dizzy to advance it. More timing at idle won't kill it. Retarded timing will.
Old 10-29-2013, 10:47 AM   #25
77ChevySharkBite
Oh okay, I didn't know that.
I was counterclockwise for the timing, but when we tried to get to 8 it just wasn't running right it was running rough, when we went to 0 it was running smooth as could be.
I'm unsure if it does or doesn't have a cam in it, if the cam is timed could that cause some issues with it as well?
Korwin
