Black engine color?
My "70 C10 has the correct engine I checked the suffix codes.Engine is black and looks to be untouched?Did they ever paint them this color or were they all orange?
![]() Join Date: Feb 2002
Re: Black engine color?
Pretty sure they were all Chevy Engine Orange in '70 [even L6s]. Black paint could indicate a rebuild. Rebuilder did not mill off engine dress codes. Some do and some rebuilders even stamp over their own numbers there.
Other possibility is that some PO repainted the truck and decided he wanted the engine to get a fresh coat of black. Can't know that w/o pulling the head(s) and mic-ing the bores.
#3 | |
What is the suffix code and casting number?
I found TAX is a 72 350 4 bolt c10 m/t.
THe only black painted ones I remember were the targetmaster rebuilts from gm. Built in Mexico. |
![]() Join Date: Sep 2010
According to the chart below, the TAX code was used on 70 and 72 engines. The valve cover TAX sticker was still on that 70 with 80 miles on it that was for sale a few years ago. My 70's original engine has the TAX code stamped on the block's pad. . . . . |
Black will help with heat dissipation.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
One more possibility -- your engine was painted on a Friday afternoon, and the paint crew [ after a couple of pitchers at lunch] -- ran out of Chevy Engine Orange, so they sprayed the whole frame and engine in Low Gloss Black until some body got back with the correct Orange paint. They could not stop the production line for anything but a safety issue. Just a theory, of course.
They were all orange (1970 SB). The engines were painted at the engine assembly plant, then shipped to the vehicle assembly plant. If there's no orange on the motor anywhere then it was most likely hot tanked and repainted during a rebuild. If the block was decked, the machinist either left the engine ID code intact, or re stamped it. Any chance of a pic of the engine ID stamp?
CHEVY/GMC VIN DECODERS |
#11 | ||
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Factory black engine paint started in the '80s.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
OK, Kieth. You were there, maybe not then, but close enough to the source that your say has weight. I respect that. My theory is officially shot down.
#14 | |
I tried a couple different posts to make sure it didn't sound too harsh... K
#15 |
Only black engines I know of are GM target engines.
