Old 10-28-2013, 08:03 PM   #1
robmc
67 shortbed
Hello, just bought a 67 shortbed - half ton 2 wheel drive - drum brakes and 6 lug of course. Can someone tell me the most cost effective way to convert to 5 lug and front disk brakes? Thanks
robmc is offline   Reply With Quote
Old 10-28-2013, 08:13 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 67 shortbed
Easiest and probably chepaest would be to find a rusted out or other wise abused 71-72 pickup or suburban and rob the parts off or find someone who did so. The whole front crossmember comes of with 8-10 bolts (i have done this but forget) 73-87 crossmember will work as well. As for rear axle do you have coil or leaf springs? if coild you can swap a 71/72 coil rear but its a little wider. Also aftermarket companies sell hybrid axles to fitthe narrower 67-70 rear but will have 5 lugs. If leaf rear find a 71/72 leaf rear (not too common) or any 73-87. Im not sure if a 73-87 leaff rear is a direct swap or not.
Several aftermarket companies sell swap kits so you have the piece of mind of having all new parts but its more expensive.
Spend some time one here andthe parts board doing some searching for more info. This seap has been civered numerous times.
WIDESIDE72 is offline   Reply With Quote
Old 10-28-2013, 08:17 PM   #3
ecgate
ecgate's Avatar
Re: 67 shortbed
The most cost effective would be a 6 lug disc brake conversion kit. Just keep your 6 lug. Thats what I did on mine. It worked out good for me. What is the reason you want to change to a 5 lug? What are the advantage to the 5 lug?
ecgate is offline   Reply With Quote
Old 10-28-2013, 08:31 PM   #4
robmc
Re: 67 shortbed
Hadn't thought of that. I think wheel selection might be better with 5 lug pattern. Definitely an idea. Aftermarket source for the 6 lug conversion ?
Old 10-28-2013, 08:35 PM   #5
robmc
Re: 67 shortbed
Old 10-28-2013, 08:42 PM   #6
Codez67Chevy
Codez67Chevy's Avatar
Re: 67 shortbed
I like pictures so SHOW SOME!!!!
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 10-28-2013, 08:43 PM   #7
ecgate
ecgate's Avatar
Re: 67 shortbed
I bought the 6 lug conversion kit from POL (performanceonline.com). You can get them with a drop spindle or a standard spindle. There are other company's that have the kits also. As far as rims go you would be surprised as too how many are out there. At least I was. But yes in general the 5 lug is more accessible but there are plenty 6 lug if you look hard enough.
Old 10-28-2013, 08:56 PM   #8
scrapmetalart
Junior Member
Re: 67 shortbed
real axles can easily be redrilled for 5 lug then use 71-72 drums.
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 10-28-2013, 09:06 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 67 shortbed
71-72 axles are a couple of inches wider than the 67-70.I think the width changed in mid year 70.The crossmember swap is a good one but you'll still probably need to rebuild it so price may be pretty equal.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
