Closed Thread
Old 10-27-2013, 12:27 PM   #1
reb162
reb162's Avatar
Is This C-10 Frame Salvagable
I'm a newer member on this board, but I've had my Gramp's C-10 since I was given it when I was 16 (1992). I drove it into college until 1999 when I got more reliable transportation. It has sat at my parents house outside Philly for the last 14 years in the weeds until I finally had it transported out here to Ohio a few weeks ago where I know live.
She never was a pristine truck (usually cab rust etc) but the years of sitting have not been kind to her. A lot more rust now...bed is toast..fenders are toast..hood is toast. About the only think I expected to salvage was the frame and cab and start from there...engine I'm on the shelf about.
Yesterday I got the bed off and finally got a better look at the frame. Its a bit worse than I remembered. When I drove it as a teen, I had already repaired the coil spring perches once. Those same areas have rotted again. There is also some rot on the left bottom rail right behind the cab (thinning actually..might be able to be reinforced but it is 1.5' long). The rear top sections of both rails are thinned where the bumper mounts go. The area at the track bar mount is also pretty well gone.
Rear Frame
One of the cross bars is gone, but that is easy to fix
Thinning of top of frame by bumper mounts at rear
Thinning of left bottom frame behind cab
Coil spring mounts previously replaced but now bad...frame thinned
New area...the area of the frame where the trackbar mounts is toast...would likely have to remove the mount and get new one and replace the bottom flange of the frame in that area
So...the question is, do I spend time fixing this frame (long bed)? I know I will be spending a lot of time just on the cab but I plan to get a welder and learn how to weld. But frame work is thicker and more critical.
Is this my opportunity to get a short bed frame or should a resurrect this thing from death?
reb162 is offline
Old 10-27-2013, 12:35 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Is This C-10 Frame Salvagable
"Burnt Toast!" Part out what salvageable and invest in something with less cancer...That thing looks like it was parked in a salt yard! "My not so humble opinion"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline
Old 10-27-2013, 01:14 PM   #3
hugger6933
I will tell you in my professional opinion that that frame needs to be replaced. As I was first reading the post I thought I could give good news till I saw the pics. Around here the frames never get into that shape and even good ones got cut up all too often. I am sure one in a whole lots better[read safer] shape could be found and started as foundation as your truck. By the way, when I say my professional opinion, I own a body shop, and have since 1987, and rebuild wrecks from there. Jim
hugger6933 is offline
Old 10-28-2013, 10:25 PM   #4
spatz
I agree, replace the frame, my 69 was just as bad and I replaced the frame. Alot cheaper and more reliable
spatz is offline
Old 10-28-2013, 10:43 PM   #5
reb162
reb162's Avatar
Spatz, since we are in the same area, I'm curious where you were able to source a rust free frame. Did you get one local or did you have one shipped from the "lucky" states (southwest). I think I'm convinced to get a new frame but looking to spend 300-400 bucks not including pickup. I'm willing to drive a bit, but not as far as the southwest.
reb162 is offline
Old 10-28-2013, 10:54 PM   #6
Todd68Chevy
Todd68Chevy's Avatar
Are you just needing a frame or are you wanting a rolling chassis? I have 6 frame right now ranging from very clean to rusted enough they need to be cut up. I am probably 3 1/2 hours away from you. If you are interested then let me know what you are needing and I will see what I have and price range for it.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline
Old 10-28-2013, 10:55 PM   #7
mmiddle
mmiddle's Avatar
Yes... replace that frame.
Look on the "sale" side of this board. the frames pop up every now and then.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline
Old 10-28-2013, 11:02 PM   #8
spatz
I got mine from a boardmember that lives about 25 miles away. I was buying some overload springs for a coil rearend, and was talking to him about his short frames when he told me he had a long box frame w/o rearend for sale. sounds what Todd68chevy has is up your alley and close by.
spatz is offline
Old 10-29-2013, 01:59 AM   #9
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Replace that frame. That thing is DANGEROUS! There are good frames in junkyards everywhere.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline
Old 10-29-2013, 06:58 PM   #10
blue 72 gmc 4x4
blue 72 gmc 4x4's Avatar
Yep that thing is done! Got lots of good frames out here!
1955 GMC Hydramatic
1959 Chevy Spartan 100
1969 Chevy C/10
1969 Chevy C/30 Bruiser
1972 GMC (Wrecked)
1972 GMC pickup..old blue
Restored Vent Windows
https://67-72chevytrucks.com/vboard/...d.php?t=766598
1955 GMC hydramatic build
http://67-72chevytrucks.com/vboard/s...d.php?t=429417
blue 72 gmc 4x4 is offline
Old 10-29-2013, 07:21 PM   #11
allons
I'm not too far from you and I can tell you that if that truck was in Ohio in the winter, the frame is TOAST. When I decided to build a truck I searched all over and found a good, but used up, C10 in dry Arizona. Even though the truck was used up, it was relatively rust free and the frame was intact.
You've got to replace that frame, it's dangerous.
There is more of us in the Mid-west group, check it out!
allons is offline
Old 10-30-2013, 06:26 AM   #12
gysgtc
I have an entire 67 frame that was sandblasted, painted, drop spindles, disc front brakes all new steering and suspension parts for $600 listed in the for sale section.
gysgtc is offline
Old 10-30-2013, 10:26 PM   #13
reb162
reb162's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any [URL="http://67-72chevytrucks.com/vboard/showgroups.php"]
reb162 is offline
Old 10-30-2013, 10:39 PM   #14
reb162
reb162's Avatar
reb162 is offline
Closed Thread
