Old 10-24-2013, 01:05 AM   #1
savatreatabvr
savatreatabvr's Avatar
Edelbrock Air/Fuel Screw Not Working!!!
I have an Edelbrock 1407 on my mid 70's C/20 454. The drivers side mixture screw works but the passenger side doesn't. I can screw it in all the way and nothing! I also hear a high pitched vacuum leak while driving at steady speeds, when I let off the gas it stops until I give it more gas. I've played with the adapter plate (Edelbrock 2696) and countless gaskets with no help. I've sprayed water around the intake manifold and carb and no leak! Could the throttle shaft be lose enough to create such a loud vacuum leak? I've checked everything else, what am I missing?
savatreatabvr is offline   Reply With Quote
Old 10-24-2013, 08:48 AM   #2
meatwagon83
meatwagon83's Avatar
Re: Edelbrock Air/Fuel Screw Not Working!!!
Did you check the hose to the brake booster? Also the little valve at the booster
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 10-24-2013, 09:08 AM   #3
Dead Parrot
Suspect every vacuum line and what they connect to. Vacuum advance on the distributor, line to the tranny if you have a TH350, line to the vacuum pot for the AC/heater stuff, power brake as mentioned, any and all emissions stuff with vacuum connections, PVC hose and valve. Charcoal canister if so equipped.
Dead Parrot is offline   Reply With Quote
Old 10-24-2013, 09:24 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
make sure the metal tubes on the carb are tight sometimes they pull out a touch,pulling hoses,a slight tap may reseat some
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-24-2013, 09:41 AM   #5
geezer#99
geezer#99's Avatar
Hook your vac advance to manifold vacuum, the idle will speed up, then turn your idle back down and your mixture screws will both work and the whistle will go away.
geezer#99 is online now   Reply With Quote
Old 10-24-2013, 11:49 AM   #6
savatreatabvr
The vacuum advance is already on manifold vacuum. I've been working on my own cars since I was 15 years old, I'm 47 now so I've tried everything I can possibly think of, numerous times. The only thing left I think it would be is the throttle shafts leaking since Edelbrock does not use bushings. I'm seriously thinking about buying another carb whether it be an Edelbrock or Quadrajet, I'm not a Holley fan and start eliminating possible causes by replacing parts. Don't know what else to do!
Old 10-24-2013, 01:36 PM   #7
geezer#99
geezer#99's Avatar
Check that both throttle plates are set in the bore the same. The one where the mixture screw won't adjust could be bent a bit exposing the transition slot completely. I had a quadrajet that did that.
Old 10-24-2013, 01:51 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
Wiggle the throte shaft. It shouldn't wiggle to much. How you fix a quadra jet is throw it on the ground real hard kick it then put it in the trash. Then bolt on an edelbrock. How you fix an edelbrock is throw it on the ground and bolt on a holley. True story back in the day haha.
If you do have a vacuum leak your idle slots may be covered way to much to respond
Another idea is if your initial isn't high enough or vacuum advance stuck or failing the idle screw is to far in and the transition slots are over exposed.
Or it's just another edelbrock that doesn't tune. In which case if it isn't causing a issue then just leave it.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-24-2013, 09:39 PM   #9
meatwagon83
there is nothing wrong with a quadrajet
Old 10-28-2013, 10:47 AM   #10
savatreatabvr
I agree! I'm a Quadrajet fan. The only reason I have an Edelbrock 1407 is I got a screaming deal on Craigslist. Ok, the only time I hear the vacuum leak is while I'm driving so the leak occurs only during higher RPM's and under a load. I meant that's only time I hear it so how do I check that, crawl under the hood and have a friend drive my truck? I'm at my WIT'S end!
Old 10-29-2013, 01:23 AM   #11
PAWS 72
PAWS 72's Avatar
I 'm havin a whistlin problem also with mine. I have checked everything. 6-8 mpg's aint cuttin it. Didnt know if swappin sides with vacumm could be done.
PAWS 72 is offline   Reply With Quote
