'67 4 WD question
my 4 wd seems to work fine but seems to only have one range. is that correct? or was there options for a low/high range in 4wd?
![]() Join Date: Jul 2001
I have a '71 4wd so not totally familiar with the '67 but you normally would have 4LO, neutral, 2HI, and 4HI shift postions. In '67 the shift positions were a sticker or decal on the glove box and that may no longer be there. In '71 & '72 the shift postions were marked on the transfer lever shift knob. Have you looked under at the transfer case / shift lever area to make sure everything is good? Nothing bent, loose shift bar linkage (maybe even missing linkage ?) Lots of things can happen to mechanicals in 46 years. '67 I believe would have had a Rockwell transfer case. Try posting in the 4wd sectin and some one more knowledgeable should be able to help. Good luck.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Re: '67 4 WD question
The shift pattern went, from all the way forward to all the way back, 2hi, 4hi, n, 4lo
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
in that case, I'm just blowing by 4hi and throwing it in 4lo....
thanks... i'll play with it this evening and see if i can feel the change below 4hi and 4lo thanks again |
That's the pattern for a Rockwell which was offered until 68, but if someone put in like an np205, it is different. My t-case is sloppy and very hard to tell where 4hi and neutral are but they are there
for some reason, I had it in my mind that it was 2hi, neutral, 4hi, 4lo... so i just pulled it all the way back to 4lo. i'll be a little more intentional when i mess with it later today..
I want to say that's what the 205 shift pattern is but not sure. I've seen other threads on how to id the transfer cases so I would figure out what case you have, again of it original it will be the Rockwell t221 but may have been swapped at some point
according to the old friend i got it from...its all original. his dad picked it up new as a shop truck for the feed store he owned.
Okay, then with the shifter all the way back, it should be pressed against the seat it will be in 4 low
Also, I will take a pic of my shift pattern sticker when I get home
I was under the impression one could get a Rockwell in a 69 as well?
Sorry for hijacking but since we're on the subject I thought I'd ask.
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
#12 | |
this is what a rockwell will look like if you crawl under the truck, and a 205 will look like this:
K10blue - thanks for posting the pics. Very helpful.
