AT Radiator Question
I swear the more I work on my truck the more I figure out just how bad the PO Frankenstiened it out.
Last weekend I flushed the radiator and was doing some other tinkering under the hood when I noticed my radiator has Automatic transmission ports on it, but of course instead of plugging the ports the PO just cut the lines about 4 inches away from the ports with bolt cutters or something and left them. My truck is a 4 spd manual with the granny first gear (and as far as I can tell it is the original trans... Atleast the SPID calls out for the 4sp). I keep kicking around the idea of installing a 700r4 or th350 in it. Is there anything I can do to check and see if the raidiator is still good as far as hooking up an automatic to it? I cant imagin it would be bad, but thought I should ask.
71 swb 350/4sp manual 5/7 static drop |
#2 | |
Re: AT Radiator Question
(lol) It should be fine. I'd flush some ATF through there to clean it out, maybe put some pressure on it to do a psuedo leak test. But there's no reason to think it shouldn't be fine when the time comes to install your automatic. Put some nice plugs in there if you are offended with the appearance. By the way, on occasion the factory will release an AT radiator on manual trans applications to keep from proliferating radiator assemblies and carrying additional part numbers. My '65 GTO is that way and I recall GM Full Size Truck doing that as well. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-29-2013 at 01:30 PM. |
#3 | |
He used old shirts to fill in rusted out holes in the fenders and then painted over them with primer. Wires are hanging everywhere not connected to anything... just wrapped around things to keep them from hanging down. There are a few wrapped around my heater hoses, and one around my power steering assy. So seeing a couple of hoses cut by bolt cutters didnt really set off any red flags...lol
#4 | |
If coolant isn't leaking out of those ports, you should be good to go after you clean it out. I'd be a lot more comfortable with those stubs your PO left on there verses the completely unguarded tank I started with.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Good to know... thanks for the feedback. Cant really complain... Saves me the cost of buying one later.
#6 | |
(lol)
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Dec 2011
trans flush is the best way to clean it out
