Old 10-29-2013, 12:52 PM   #1
77ChevySharkBite
77ChevySharkBite's Avatar
Spark Plug Wires
I'm wanting to freshen up the spark plug wires because well there old and probably be a good idea to get some new ones.
My only real question is, will the 90 degree boots work? I have a 1977 Chevy C10 Chevy 350 with Long tube headers.
I'm trying to find a good set anyone have any recommendations not trying to break the bank but want a decent set.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 10-29-2013, 03:31 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Spark Plug Wires
I run 90s on mine. A wire loom helps a lot with everything I run Taylor thundervolt or spiro pro's on everything all run.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-29-2013, 03:31 PM   #3
tucsonjwt
NAPA wires are by Belden and are the best in my experience. I stay away from super duper whiz bang latest design wires. Out here the desert heat is very hard on electrical components and plug wires are particularly subject to heat failure. I have found that cheap auto parts store wires have occasional tiny breaks in the boots which cause shorting and misfire - it is almost impossible to see those defects with the naked eye. I just replaced my NAPA Beldens with the same wires (though a different style now) after 11 years of use just because I did a major tune up, but the original plug wires were still OK.
tucsonjwt is offline   Reply With Quote
Old 10-29-2013, 05:26 PM   #4
clapage6
I like the taylor spiro pro's with the 45* boot personally this on my 454
clapage6 is offline   Reply With Quote
Old 10-29-2013, 05:30 PM   #5
77ChevySharkBite
Thanks fellas appreciate all the help!
Korwin
Old 10-29-2013, 05:37 PM   #6
geezer#99
geezer#99's Avatar
Get a cut to fit set and run them down the back of the motor, along the oil pan rail and up to each plug.
