10-24-2013, 11:31 AM | #1 |
Any 73-80 with MILD Dropmembers?
Looking for some pics of 73-80 trucks with the mild dropmembers. Ideally, with 20" wheels. A pic aired out and another at ride height would be perfect. How long have they been taking to install? I will be taking my DD apart once I have EVERYTHING for the front in hand and hoping to knock it out over a weekend. Is this too optimistic?
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
10-24-2013, 06:02 PM | #2 |
Re: Any 73-80 with MILD Dropmembers?
I don't have any pictures of the Mild on a square body, unfortunately. You might be able to install the front on a long weekend, or 2 long days. Just take your time going through everything and the necessary steps. It is easiest to pull the engine when installing.
10-29-2013, 07:14 PM | #3 |
Nobody?
10-29-2013, 07:32 PM | #4 | |
Getting it done in a weekend? Id say yes if everything goes well and you don't plan on painting anything while you are there. I have ran into problems (stripped bolts, wornout parts, wrong parts from the store, etc) with every front suspension I have worked on. Do you have a back up DD? If not I would start Friday night that way you have an extra half day to fix whatever you find.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
