Old 10-29-2013, 07:43 PM   #3576
1Bad 37
1Bad 37's Avatar
Re: Tootsie build for my mother with cancer
I'll trade you motors! Mine runs great! You know you want a Corvette motor!
1Bad 37 is offline   Reply With Quote
Old 10-29-2013, 09:47 PM   #3577
Hart_Rod
Hart_Rod's Avatar
Originally Posted by superflysteiny View Post
Rob no there are no codes being thrown. I may pull harness and computer and redo it. I have access to one of the best ls tunners and engine builders on the west coast we are all trying to figure the the truck out. We will figure it out but it just depends on if its before sema. i hate to push the truck into Sema
I'm sure it's something simple, it usually always is....
Hart_Rod is offline   Reply With Quote
Old 10-29-2013, 11:06 PM   #3578
jlsanborn
jlsanborn's Avatar
I would agree that it's gotta be something simple. Don't be too quick to blame the "black box". Get some fresh eyes on it man, someone that hasn't gone down the same path as you and your builder. Odds are that the computer did not somehow get effed up, but that someplace in all your custom wiring and stuff something is just not hooked up or is hooked up backwards or something. I bet you're one wire away from CRAZY!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 10-30-2013, 08:14 AM   #3579
mcbassin
Still Learning
mcbassin's Avatar
You have spark at the plugs, fuel pressure at the rail and no start? Have you checked to confirm the injectors are firing with a noid light? Does it even try to start?
Sometimes it's something simple. like a ground wire or not having power with the key on and during start. There are some sharp guys on the engine forum on here in the LS specific section that can help you through the diagnostic. I'm sure you have some great help already but it never hurts to get multiple opinions.
Old 10-30-2013, 08:20 AM   #3580
Low Elco
Hope you made some progress last night. Fingers crossed for you.
Low Elco is offline   Reply With Quote
Old 10-30-2013, 11:19 AM   #3581
superflysteiny
superflysteiny's Avatar
Its all good. I have some of the best guys on the west coast working on it . Mark Roman is the tuner he is all over all the ls boards. He reflashed the computer. I had a big engine builder in town come over last night he looked at it. The harness is fine but there is no spark and injector pulse so we are leaning toward a bad computer. Thank you speartech. By the way I did call them and they were rude and not helpful in fact they were the opposite. So they took my 1400 and refuse to help in the situation so nice. Well at any rate we will look at the computer replace and reflash and if the does not work it will be getting rid of the e40 computer and doing a new wiring harness from another company. I will take it up with speartech later. Also it will not run for sema if the computer issue is not the issue just running out of time. Sucks but I bought what was supposed to be a good product and its not so it is what it is. Thanks for all the help guys
superflysteiny is offline   Reply With Quote
Old 10-30-2013, 11:38 AM   #3582
PBFAB.COM
PBFAB.COM's Avatar
Frustrating to hear about the issues with what appears to be the harness or ECU. I have used Speartech in the past with good results... never had a problem. There was never the need for any troubleshooting/customer service from them, but sounds like that was a good thing. Sorry to hear about the lack of help you are receiving from them.
I am sure you will get it figured out, as you always seem to find a way.
Tootsie is looking incredible, and you should be extremely proud of what you have accomplished over the past year. Kudos my friend!
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-30-2013, 11:40 AM   #3583
superflysteiny
Thanks Mike all of this has been checked at least three times three different ways. The 12volt power has power while cranking. all grounds are good and have been checked. We have checked the harness and all 12volt connections we have checked it all. It all checks out so we will get another computer. It has made it hard because speartech told me to go with the e40 computer which is a one year computer and to be honest with you from what I understand is not very good. So I guess we will have to wait and see. If the truck does not run it will be one expensive paper weight
Old 10-30-2013, 12:05 PM   #3584
superflysteiny
Nate
Thanks Nate I appreciate the kind words. I just really did not want to push the truck in to sema Its kind of embarrassing for me but I guess it is what it is.
Old 10-30-2013, 12:11 PM   #3585
youngrodder
youngrodder's Avatar
You will get is figured out. One (dumb) question is while you have been doning all of this trouble shootuing have you unhooked the battery at all? On my LT1 when I was having trouble firing the motor I finailly figured it out but it still didn't start until after unhooking the battery and letting the computer reset. I was surprised when I went back to try it that it fired. Other than hooking back up the battery I really didn't do anything differnt.
I'm sure that you tried it but I figured that I would ask.
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-30-2013, 12:16 PM   #3586
superflysteiny
Good luck
Marc
no I have not done this yet. I will try it
Old 10-30-2013, 12:26 PM   #3587
Bhelton
Bhelton's Avatar
The more I look at this build the more I'm amazed at the quality and attention to detail!
Bhelton is offline   Reply With Quote
Old 10-30-2013, 01:25 PM   #3588
superflysteiny
Thank you now all I need is for the truck to run
Old 10-30-2013, 01:31 PM   #3589
5150
C10 Club Tennessee
5150's Avatar
I'm there if you need me to push again. It would be an honor.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 10-30-2013, 01:50 PM   #3590
Gus350
68 C 10
Gus350's Avatar
HELL I'd love to help push this beautiful beast. But I hope you get it running for your own sanity. This truck looks killer. Prayers for your family from mine.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 10-30-2013, 01:50 PM   #3591
396ci
396ci's Avatar
2nd in line for the Tootsie pit crew!
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 10-30-2013, 05:20 PM   #3592
superflysteiny
Thanks guys we may be pushing lol
Old 10-30-2013, 05:28 PM   #3593
Rochlow
Hell at least your going. I've never been
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 10-30-2013, 06:23 PM   #3594
superflysteiny
This is my first yr too I am really excited
Old 10-30-2013, 06:34 PM   #3595
Hart_Rod
Hart_Rod's Avatar
Can you email me a copy of your tune? robhartley@aol.com
Old 10-30-2013, 06:44 PM   #3596
superflysteiny
Rob we got it brother. Placed a new computer on and we have spark. So we are putting the truck back together and I will post it if we get it running. Looks like we found the problem. I will be calling speartech in the am and I will not be nice after the way he treated us.
Old 10-30-2013, 06:45 PM   #3597
superflysteiny
Also thank you Rob for the help
Old 10-30-2013, 06:46 PM   #3598
Hart_Rod
Hart_Rod's Avatar
Sweet! I understand where you are coming from.....
Old 10-30-2013, 07:40 PM   #3599
Rusbuilt
Rusbuilt's Avatar
Glad to hear you got the issue fixed!
Rusbuilt is offline   Reply With Quote
Old 10-30-2013, 09:17 PM   #3600
sduckworth13
sduckworth13's Avatar
This is more exciting than the count down for lift off of the space shuttles .
Scott
sduckworth13 is offline   Reply With Quote
