Swap Saginaw 4 speed manual for 350 Turbo Auto
Thoughts? The guy has a brand new 350 turbo still in the box. He's asking $500 for it. Seems expensive to me.
Would it bolt up directly to my 65? I have a small block in it now. What else would I need to make the swap work? Should I keep my eye out for a different type of transmission? Thanks! |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Swap Saginaw 4 speed manual for 350 Turbo Auto
I'm just picked up a th350 that I'm going to swap out my 4-speed sm420 this winter.
I'm rounding up the parts now. I found several threads in these forums on the topic. If I had the money, I'd probably go with an auto that has an overdrive. I don't have the money, and I don't drive my truck much, so the th350 should be fine for me.
#3 | |
60-66 Nut
If it is a quality rebuild, $500 is not out of line. The cheapest price I have found is $650.00 with a converter, and not including a core charge.
