Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-30-2013, 07:52 AM   #1
low&slow
What about bags?
So I got this idea about running bags up front only on my 69 c10 for adjustable ride height. My original plan was to have a track only truck, but I had an idea of making it street worthy too. Is it possible to run bags at the drag strip?
Only problem I can think of is that my truck might just lift the wheels off the ground and when it lands, it may just blow the bags out.
Anyone see a problem with it?
low&slow is offline   Reply With Quote
Old 10-30-2013, 10:22 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: What about bags?
I think there is probably a good reason you don't see air bag suspension at the track. Blowing the bags I don't think would be an issue, it's the lack of stored energy would be pretty counterproductive at the track IMO.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-30-2013, 06:02 PM   #3
low&slow
What do you mean by stored energy?
Old 10-30-2013, 10:33 PM   #4
tinydb84
tinydb84's Avatar
It has to do with weight transfer from front to rear. Someone will chime in with more info but this is a good read regardless:
https://www.cachassisworks.com/Attac...1-226_drag.pdf
Edit: Look at page 5
David
Instagram: myfabguy
Old 10-31-2013, 11:13 AM   #5
Marv D
Marv D's Avatar
In simple terms,, a 1500 pound load on a front suspension spring, has 1500 pounds of 'lift' wanting to be released as the leverage of the tire / torque removes that weight.
It wants to 'help' the leverage of the suspensin take the weight off the front, and put it onto the rear.
Old 10-31-2013, 11:47 AM   #6
Marv D
Marv D's Avatar
Oh,, and a spring will have a LONG travel to release that 1500 pounds, where a air bag will only have a very few inches of travel to release all of it's 'stored energy'
That make sense?
Old 11-01-2013, 11:33 PM   #7
low&slow
So you're saying that by having bags in the front, there is less energy being stored than there is with springs/shocks resulting into less front end lift also resulting into less weight being put on the rear end for a loss of traction?
I think I'm beginning to understand. So for a shock that has a lot of travel, the front end weight will lift higher putting more weight on the rear rather than having a bag and only a little travel for not very much weight transfer?
Old 11-01-2013, 11:45 PM   #8
tinydb84
tinydb84's Avatar
1. Yes
2. I assume you mean spring? Yes, typically you need a softer (as it will be longer) spring to maintain a good ride height
David
Instagram: myfabguy
Old 11-01-2013, 11:57 PM   #9
low&slow
Yes I meant spring. Makes sense for why there isn't bags at the track.
What about those adjustable springs. Wouldn't I be able to set them up for track use and then for the street, turn them a little and lower the front of the truck? Or vise versa?
Old 11-02-2013, 12:03 AM   #10
tinydb84
tinydb84's Avatar
Adjustable springs? as in coilovers? yes but there arent really coilovers for our trucks unless you do a porterbuilt/scotts/etc set up
David
Instagram: myfabguy
Old 11-03-2013, 10:28 AM   #11
Marv D
Marv D's Avatar
Here's a picture to do the 1000 word thing.. A full tilt drag race front suspension/spring (and this is just a 2600 pound car) look at the length of the spring to hold up a very light car. I put travel limiters on it to limit the rise and try the limit the wheelstands.
Where an airbag has a whopping ,,, what 3" maximum travel to unload ALL of it's support.
You commonly find airbags in the right rear coil spring as a chassis tuning aide to help plant both tires evenly. But as a suspension... there better left to the slammed street crowd
just imo
Old 11-03-2013, 04:45 PM   #12
regan wilson
regan wilson's Avatar
Marv that was a good post. Now give us some launch pics like the one in your YB avatar. The Chebby Too is cool!
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 11-03-2013, 09:54 PM   #13
Marv D
Marv D's Avatar
Lol., here's the 'airtime' video that avatar photo came from I think.. she used to get up on the tire just a bit.
http://www.youtube.com/watch?v=0BDdg...ature=youtu.be
Man that is SOOOooooo hard on parts!
Sparks was a few gouges in the oil pan and header extensions. I had to try and stand the tires back up straight in the stock Chevy II front suspension after every race. (Hence the AJE strut front clip added in the pic above)
Old 11-08-2013, 11:55 PM   #14
low&slow
Not sure if any of you have seen this thread, but I've been reading through it and gave me an idea for the adjustable coil overs up front. You guys think it will work for racing purposes?
http://67-72chevytrucks.com/vboard/s...d.php?t=266485
Old 11-09-2013, 05:07 PM   #15
tinydb84
tinydb84's Avatar
Anything can work with enough fab. Do you need to make adjustments? Are you planning on driving it on the street and need to preform really well at the track? It seems like a lot of work to me. You can also buy new springs that are longer and softer that will do the job and ride decently on the street.
David
Instagram: myfabguy
Old 11-12-2013, 09:40 PM   #16
low&slow
Do I need to make adjustments, No not necessarily. Only adjustments I'd make is at the track. As for street driving, I may do that occasionally to shows, local cruise, or parade. I'm not concerned about how well it is on the street. I was just thinking that for street use I could some how lower the front a bit for looks and then at the track pick the front back up a bit so all the weight isn't so low to the ground in the front. I was thinking that if the front is lower than the rear at the track, then it'd take longer for the weight to transfer to the rear than if the truck was a little more level. If any of my jumbled mind makes sense.
Old 12-08-2013, 09:20 PM   #17
low&slow
Any more input?
Old 01-30-2014, 10:00 AM   #18
Wasted Income
Boosted Member
Wasted Income's Avatar
My street truck ran high 11s on bags all the way around. How fast are you planning to go?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-30-2014, 03:31 PM   #19
low&slow
I want to get into mid 10's at the fasted, but I want to lift the front wheels off too just a little bit if possible with zero fiberglass
