Old 10-30-2013, 11:04 PM   #1
jks67ss396
inferior rag joint?
Guys
I bought a rag joint from a reputable vendor that a lot of guys recommend here. The rag joint has regular bolts going through the rubber, where as better rag joint have the collared bolts (see thread below)
http://www.camaros.net/forums/showthread.php?t=113278
Have you guys ever used the rag joints with the regular bolts? Any problems with the install or later on?
Wondering if i should get the collared bolts or a better rag joint
thanks guys
jks67ss396 is offline   Reply With Quote
Old 10-30-2013, 11:17 PM   #2
Robznob11
Robznob11's Avatar
Wink Re: inferior rag joint?
Well if you are running manual steering loose the rag joint and get a grand cherokee shaft bolts right to the box and very little grinding on the column side and is much tighter and better feel not to mention it has double u joints
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-30-2013, 11:20 PM   #3
jks67ss396
nope... running power steering
thanks though!
Old 10-31-2013, 02:39 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
I will be doing a swap using a Jeep Cherokee (not Grand Cherokee) intermediate shaft to replace the section between the column and the power steering box on my C20 truck. I got the shaft at the pick a part for $20. The replacement rag joint was much more that that. I hope to work on it this weekend. I will post a how too once I get it done.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-31-2013, 07:11 PM   #5
bdiamond
X2 on the NOT Grand Cherokee.
bdiamond is offline   Reply With Quote
Old 11-05-2013, 11:17 PM   #6
Sir Fisher
Sir Fisher's Avatar
Not trying to hijack... figure i ask since we're on this topic, but is there a difference in the different year model on the rag joints?? or is it the same throughout 67-72??
Thanks,
Wayne
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 11-06-2013, 12:09 AM   #7
Robznob11
Robznob11's Avatar
Thanks,
Wayne
i believe the rag it self is the same but the metal section that mounts to the gear box is different for power or non power the grand cherokee shaft is a direct bolt on for non power. From the other post maybe the regular cherokee works for power not sure. But mine was 93jeep gc
LED TAILS
