10-23-2013, 04:11 PM | #1 |
59 Chevy frame swap
Ok I haven't been on in a while because I sold my 67. I found one hell of a deal on a 59 1/2 ton Apache swb step side. I've done a little research and I see people talking about doing a frame swap from a s-10 but I was told that a frame out of a late 70's to early 80's frame would work with little work. I just wanted to get opinions on what would be the easiest? Thanks for the help!
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 |
10-23-2013, 05:55 PM | #2 |
Re: 59 Chevy frame swap
Look at the top of the page sub forum "labeled projects & builds" there are some trucks using the frame you are discribing
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
10-24-2013, 12:56 PM | #3 |
10-24-2013, 01:19 PM | #4 |
^ nice lookin truck !!!
10-24-2013, 01:27 PM | #5 |
you could use an S10, but you'll have to shorten the frame, make up or modify all your cab mounts, raise your bed floor and use spacers to move your wheel out further.
The 73-87 chassis will work but the track width is much wider than stock which means you can't lower it a great deal. EZ Chassis Swaps make a kit to adapt the 55-59 body onto a 73-87 Chassis. Or you can put it on a car chassis like a Caprice. Personally, if your frame is in good shape, I'd buy a 2md generation Camaro and weld on the front clip from it
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
10-24-2013, 01:32 PM | #6 |
gettin snowed in yet? ^
10-24-2013, 03:03 PM | #7 |
use the stock frame and modify it, is the easiest and usually the least costly.
all new mustII, 40 yr old camero clip or lots of other options up front. flipped axle on stock springs, 4 bar, 3 bar w/ panhard or lots of options out back. either one is easier than a frame swap and your much more likely to finish it. read some of the builds here, most tf truck builds have the stock frame under them.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-24-2013, 03:03 PM | #8 |
no snow yet buddy, well, nothing that stuck around for any amount of time. it's coming soon though
11-01-2013, 12:58 PM | #9 |
Nice lookin, solid truck! Keep it up!!
