Old 11-02-2013, 10:11 AM   #1
concretekiller
EZ Wiring Harness and brake light switch
Ugh! Keep blowing fuses. Already spoke to their tech support and determined the brake switch is still good. I hook up brake switch power to the switch, press the brake, all is good. Hook the white wire up to the column from the brake switch, BOOM, blown brake fuse. Any insight?
concretekiller is offline   Reply With Quote
Old 11-02-2013, 10:21 AM   #2
davbowen
davbowen's Avatar
Re: EZ Wiring Harness and brake light switch
you got a dead short some where. check that no power wire is grounding out.
davbowen is offline   Reply With Quote
Old 11-02-2013, 03:06 PM   #3
Snailed
Snailed's Avatar
Ever try the compass trick for finding shorts?
http://www.inliners.org/tech/tech6.html
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 11-03-2013, 01:54 PM   #4
concretekiller
Ok figured out brake lights (replaced rear connectors and one wasn't properly installed in the housing). Now I just need to get my turn signals working. I don't have the indicator wires hooked up to the gauge panel yet. Does that need to be done first?
Old 11-03-2013, 02:30 PM   #5
KJSR
KJSR's Avatar
They will work without the indicators hooked up.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 11-03-2013, 02:38 PM   #6
concretekiller
Yea I didn't think so.
Old 11-03-2013, 08:24 PM   #7
concretekiller
Little update, blinkers come on, but stay bright. Don't blink back and forth. Thinking it may be the flasher relays that came with the kit. Will post update tomorrow (I have LED fronts and rear's).
Old 11-03-2013, 08:49 PM   #8
Mack B
Mack B's Avatar
I've got no first hand experience with this but I read it on this forum....I think..Pretty sure someone said it takes a special flasher to work with LED lights.
Mack B is offline   Reply With Quote
