Closed Thread
Old 10-29-2013, 07:10 PM   #8251
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Re: What did you do to your truck today!
Mounted alternator on passenger side so I can get a power steering pump in there. Search goes on for that and a 4bbl. Just keep throwing money at it
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 10-29-2013, 07:26 PM   #8252
gvw5400
gvw5400's Avatar
67 slider
Great little stepper!
I KNOW the dirt road pain, but wouldn't live anywhere else.
All the best ,Dirk
gvw5400 is offline
Old 10-29-2013, 11:44 PM   #8253
mmiddle
mmiddle's Avatar
Over the last few weeks I have spent a little time with the wifey tearing down my '70. We removed all the interior... Shag carpet and all. Took out the finder wells, polished the grill, put four tires on it that hold air and a few other things. The rust is as expected for these trucks. However the PO hacked up the tunnel pretty bad putting a floor shifter in it. In the late '70's or early '80 he did a lot of really crappy body work on it. The truck was apparently road hard and put up wet... Also found that it had a 5th wheel mount in the bed after cleaning out all the leaves. The truck sat under a grove of trees since 1986 until this July.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline
Old 10-30-2013, 05:42 PM   #8254
BlacklandCamper
Found out my quadajet is unusable. I managed to get the secondary needle bracket bent back to where it should be, but found one main needle is bent, and the other is broken. Good news is I have a good carb lined up, just need to collect it.
Found a set of headers for cheap, slightly used, going to clean them up and paint them. I figure headers, carb, and an intake will be enough until I can build the engine I want.
Also managed to get under the rear end and found a tag bolted to the diff cover. It says my Dana 60 has 4.10:1 gears. :-)
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 10-30-2013, 07:04 PM   #8255
sboris
sboris's Avatar
Got some help with my letters..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline
Old 10-31-2013, 06:27 PM   #8256
Patina'd_402
Patina'd_402's Avatar
Found out I have a bad battery.... Getitng a new one tomoro.
Hopefully that was my charging issue.
'70/C10/402/TH400.
Patina'd_402 is offline
Old 10-31-2013, 08:46 PM   #8257
Avitech
Avitech's Avatar
Replaced the cracked and broken steering wheel. New wheel came from a Jeep Wrangler Laredo in the pick and pull yard. Had the same mounting pattern so an easy swap. I replaced the Jeep emblem with a carbon fiber button I made.
1990 Suburban Silverado
350, SM465 and 35" tires
Avitech is offline
Old 10-31-2013, 08:59 PM   #8258
awbrown
I let the neighbor borrow it for his Halloween display ... don't know what the draw was ...
awbrown is offline
Old 10-31-2013, 09:12 PM   #8259
Wheel looks good in there.
Palf70Step is offline
Old 10-31-2013, 09:38 PM   #8260
In The Ten Ring
I bought a GM door handle from a guy on here. Didn't really need it but I told him I'd buy it and I like to do what I say I will.
It's gotta be better than that repro on there now! LOL
In The Ten Ring is offline
Old 11-01-2013, 10:54 PM   #8261
muckyp
muckyp's Avatar
Installed rear bumper and new radiator. Getting so close!
70 SWB 454/TH400
muckyp is offline
Old 11-02-2013, 09:02 PM   #8262
sbell87
Thumbs down Re: What did you do to your truck today!
Before
sbell87 is offline
Old 11-02-2013, 09:03 PM   #8263
sbell87
After
sbell87 is offline
Old 11-02-2013, 09:14 PM   #8264
ksshane
ksshane's Avatar
in the process of installing my rear flip kit. Got it tore apart and then everything put back into place. Decided to call it a night and take a fresh look at it in the morning to make sure we are installing the kit correctly before tightening everything down. Then moving to the front to install drop spindles and lowering springs.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline
Old 11-02-2013, 10:12 PM   #8265
In The Ten Ring
Tried to buy a NOS passenger handle but the last email from the seller was a bit confusing. I sent an clarification email but still awaiting the answer. Hopefully I can still get the handle.
Old 11-03-2013, 05:45 PM   #8266
Patina'd_402
I made my truck a mini-me...
'70/C10/402/TH400.
Old 11-03-2013, 06:10 PM   #8267
Syndrome
Pulled the battery out of it and put it on the charger. Its starting to freeze here and I didn't my truck running yet so I figured I better pull it than lose a brand new battery.
1970 GMC
Syndrome is offline
Old 11-03-2013, 09:06 PM   #8268
In The Ten Ring
I paid for the passenger side NOS door handle.
Old 11-03-2013, 09:11 PM   #8269
ksshane
ksshane's Avatar
Finished up the rear flip. Lowered the rear 6.5", and will probably be a little more once I install the c-notch.
Got the front end torn down and the new ball joints installed (that was fun )
Was hoping to get away with just installing new drop spindles and cutting a link out of the springs, but once the old springs came out it was obvious that the PO had heated the springs. So picking up some 3" dropped springs tomorrow.
ksshane is offline
Old 11-03-2013, 09:24 PM   #8270
hayhauler71
hayhauler71's Avatar
Took it out for a ride along the Mississippi river with my daughter probably the last ride of the season
Fuzzy
hayhauler71 is offline
Old 11-03-2013, 09:35 PM   #8271
Boog
laying low
Boog's Avatar
That's cool Fuzzy.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 11-03-2013, 09:52 PM   #8272
68'CTown
68'CTown's Avatar
I have a 68 truck and just got done taking out my front suspension and putting in a 74 cross member and front suspension for the easy disc brake conversion. Now needing help on what engine frame brackets to use.
Thanks!
Craig
- Every day is a new opportunity. You can build on yesterday's success or put its failures behind and start over again. That's the way life is!
68'CTown is offline
Old 11-03-2013, 11:54 PM   #8273
AustinScott
AustinScott's Avatar
Sprung a power steering leak.....
It was only a matter of time with the hose rubbing on the inner like it has been.
I guess its time to get two new hoses made to the correct lengths...
NAPA?
Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline
Old 11-04-2013, 07:33 PM   #8274
swamp rat
swamp rat's Avatar
Originally Posted by sbell87 View Post
After
Bed liner? Looks textured.. Looks Great too.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline
Old 11-04-2013, 07:37 PM   #8275
sbell87
It is! Works great! I have it in most of my trucks. Kills the sound!
sbell87 is offline
Closed Thread
