Old 12-11-2003, 09:08 PM   #1
ocbaud
Garage Queen Material
tooth of flywheel?
how many teeth will i need on my flywheel?
ocbaud is offline   Reply With Quote
Old 12-11-2003, 09:25 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
all of em
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-11-2003, 09:38 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Depends on which starter you use. With the offset bolt holes in the starter nose, like your 305 has, you would need the 14" 168 tooth flexplate. I can't remember if a 71 block will work with offset starters or not, but with a straight across bolt pattern on the nose it uses a 12-1/2" 153 tooth flexplate.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-11-2003, 09:48 PM   #4
ocbaud
and any of them should work fine with my th350c?
Old 12-11-2003, 10:43 PM   #5
TIMSPEED
TIMSPEED's Avatar
I would say it depends on what year block you have. If you have the staggered bolt pattern starter (normal with a small block) you'll need a 168-tooth flexplate/starter. Trust me, I know this from experience.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-11-2003, 10:51 PM   #6
ocbaud
if it was a '71 block, what would i need?
Old 12-11-2003, 11:20 PM   #7
swervin ervin
No a 168 tooth is not normal, or what you think is normal.
Most all small blocks are drilled and tapped for both starters. I have had many small blocks with straight across bolt patterns. But, not every small block will have both patterns. I suggest you wait until you see what the block you use has. A lot of the older blocks only had straight across patterns. I know this because I'm old and have changed many starters in my days.
Mike
1985 Chevy C-10
Old 12-12-2003, 12:06 AM   #8
TIMSPEED
TIMSPEED's Avatar
I thought Big blocks were straight across and small blocks were staggered? (At least on chevy's) I could be wrong, because the old small block I've seen is a 75 (mine )
See Them Here
Old 12-12-2003, 12:43 AM   #9
swervin ervin
You are wrong. :p
Old 12-12-2003, 10:34 AM   #10
Nvbowtie
Nvbowtie's Avatar
Ask the builder, the small blocks can use either straight or stagger at least my block is that way.
and do yourself a favor,
get it lined up to be sure while it's on the engine stand,
or cherry picker before you put it in.
or just buy a mini starter with multiple mount positions for 153 or 168, thats where I am heading now.
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
