11-02-2013, 04:19 AM | #1 |
Changing Front Track width on 47-54s
I ask because I'm looking at some IFS conversions (not clips) that increase track width to 58-59"
From what i read stock width of 56" goes to 56.5 with either disc brake kits most Mustang ll conversions. I've seen pics of a lot of front clips done with Nova, Camaro & Monte Carlo, etc. & I believe these range from 58-59.5 ". Does this increased track width have bad consequences as to looks, handling etc.? |
11-02-2013, 09:36 AM | #2 |
Re: Changing Front Track width on 47-54s
Wider is better, at least if you're a Pontiac fan. Many of the guys that convert to 4X4 end up with wider axles, too. As long as wheels fit under the fenders correctly and don't rub you're ok.
11-02-2013, 10:00 AM | #3 | |
11-02-2013, 10:22 AM | #4 |
They're nervous for a reason, IMO. The wider the track the tougher it is to get a proper turning radius without hitting the fenders, especially if wider is combined with lower. A serious consideration depending on the stance you see for your truck. Also, if you like wheels with some negative offset(deep dish) like I do, you will have more trouble the wider your track is. If you like newer style wheels with positive offset that are close to flat on the outside then track width is less of a concern. Your builders, like I would, probably want you to be aware of these things so you don't show up 2/3 of the way through the build saying "I really like these 8" wide 17" wheels with a 3" backspace for the front" and they have to say it can't be done. Just some things to think about.
11-02-2013, 10:43 AM | #5 | |
I am looking to only drop the truck 2" and very slightly widen the stance via tires |
11-02-2013, 11:58 AM | #6 |
I've got a straight axle but maybe this will help you.
Stock track is 58" plus 1" wheel adapters both sides giving a total of 60" track width. The axle is dropped 3" with Corvette rally wheels that have a 3" back space. I run 215/70/15's. I don't have any rubbing issues yet and its been this way for lots of years. Good luck. |
11-02-2013, 12:06 PM | #7 |
With that size tire/wheel combo and the minimal lowering, I don't see track width as being a problem. Your combo should be close to the same as nvrdone's and it works.
11-02-2013, 12:19 PM | #8 | |
11-03-2013, 03:01 AM | #9 | |
