Old 10-30-2013, 03:01 PM   #1
terry b
terry b's Avatar
Mounting sport mirrors on 1972.
So i found a old thread on how to locate the holes for the sport mirrors. What i need to know is what size holes did the factory drill in the doors to mount the mirrors? Were the factory screws flat or domed on the head? Are you guys using stainless steel screws or crome? Where are you buying them? How are you holding the backing plates in place? Silacone? Can you get your hand in the door to hold the backer in place to start the screws? Thanks for any help.
terry b is offline   Reply With Quote
Old 10-30-2013, 04:32 PM   #2
Lou Boffa
Lou Boffa's Avatar
Re: Mounting sport mirrors on 1972.
yes, you can get your hand in there--with some twisiting around. Definitely a 2 man job.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 10-31-2013, 03:27 PM   #3
terry b
terry b's Avatar
Any more input?
Old 10-31-2013, 11:21 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
Not impossible with one person but easier with two. I used gaffers tape i had to hold backing plate in place. Duct tape would probably be fine. The repro mirrors bought included countersunk phillips head screws. I dont think they are stainless. I believe the holes are 1/4" as the screws are pretty small. I believe they are #8, possibly #10.
WIDESIDE72 is offline   Reply With Quote
Old 11-01-2013, 02:03 PM   #5
terry b
terry b's Avatar
Thanks for the come back. I just bought the backer plates from a member and your right the screw holes in them are small. Do you know how the factory mounted the plates if at all.
Old 11-01-2013, 03:03 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
They weren't fastened. When you take the screws out of the mirrors the backing plates fall to the bottom of the door...
LockDoc
Leon
Old 11-01-2013, 04:15 PM   #7
terry b
terry b's Avatar
Well thats one way to do it. I'll bet that has bummed a lot of people out over the years. Do you see any problem with glueing them in place when you mount them?
Old 11-01-2013, 06:06 PM   #8
john
member #16
john's Avatar
Here's a link with the hole sizes and measurements.
http://67-72chevytrucks.com/vboard/s...d.php?t=179279
john is offline   Reply With Quote
Old 11-01-2013, 06:49 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
Believe it or not I have removed old mirrors and installed new ones on a 72 without removing the door panel! You loosen all three screws but take one screw out at a time. Rotate the mirrorand imstall the new mirror withe the screw you removed. Repeat two more times. To be honest its probably easier to just remobe the door panel!
Ober the years I have always looked for trucks thy had sport mirrors by the extra holes in the door after the precious owner taxked some aftermarket mirrors on. This is a sure indicator that there is probably a mirror mounting bracket lauing in the bottom of the door from the removal process. I had this luck a pot inthe 80's when there seemed to be a lot more of these trucks in the wrecking yards. Not so much any more. I couldnt believe my luck ealier rhis year when I ran across a 72 highlander with a factory tilt and a lot of other good parts i stripped off including a rust free core support!
Old 11-02-2013, 01:47 PM   #10
terry b
terry b's Avatar
Lots of good info thanks guys.
Old 11-02-2013, 02:17 PM   #11
YBNORML
YBNORML's Avatar
I take my mirrors off when I store my Blazer, the cover fits better. I got annoyed with the backing plates so I but a dab of silicone on the backing plates before I installed them, now it's a one man job
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 11-02-2013, 03:32 PM   #12
terry b
terry b's Avatar
Thats what i have been thinking. Once i get the door pannels back on i don't want to have to take them back off.
Old 11-03-2013, 04:59 AM   #13
eglide78
Double sided 3M tape is what I used. A lot cheaper than all the beer I have to buy to coax someone over to help.
1964 C10... work in progress
1971 GMC 2500 Sierra Custom Camper
eglide78 is offline   Reply With Quote
Old 11-03-2013, 08:46 AM   #14
terry b
terry b's Avatar
I hear ya, I like to do most all my work by myself. Good time to unwind.
