Transmission Help
The truck I bought recently came with a tranny in it, the pan says 350 Turbo on it... How would I go about verifying that it really is as such?
1972 Chevy C-10 1/2 ton longbed project 1989 Chevy 1/2 ton shortbed "If a man does his best, what else is there?" "A pint of sweat saves a gallon of blood"-George Patton |
![]() Join Date: Mar 2012
Re: Transmission Help
compare the pan shape to one on the web, easiest way
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
The pan should be square but one corner is at an angle.
how is the fishing up in Kaw Lake???
Thanks guys I appreciate it.
Mike- Im not a big fisher but my friends dad is and he did very well everytime he went out. Are you originally from the area?
We have success, It is square with an angled corner on it.
Next question I have... If i get a mild 402 or 454 can I use this transmission?
It should handle a 402 with some care not to beat on it every time the light goes green, but I definitely wouldn't trust it behind even a stock 454. At that point, the TH350 should be upgraded, or possibly a swap to a TH400.
71 K20 64 GMC mud truck |
From one Okie to another. I always thought a turbo 400 worked best with a 454. My 2 cents.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
Thanks for the input guys... I was thinking a Turbo400 would more than likely be needed but as I am not experienced with transmissions I figured it best to ask
I'm old school but a 700r4 is hard to beat.
#11 | |
A properly built TH350 would handle the power, but is it worth it? By the time you build the 350, you could buy a new 400. Only thing with the 400 is the extra rotating mass eats a little extra HP.
Thanks for the help. 700r4 looks like it will be a little too expensive
#13 | |
I agree the 400 turbo is the way to go with a big block, but you have to change drive shaft and yoke, and detent setup
Bigmac73- Small world ehh? Thanks for the info 400 turbo is the way I'm going to go. Is the driveshaft,yoke and detent setup hard to change?
1972 Chevy C-10 1/2 ton longbed project 1989 Chevy 1/2 ton shortbed "If a man does his best, what else is there?" "A pint of sweat saves a gallon of blood"-George Patton Last edited by gunrunner95; 11-03-2013 at 11:39 AM. |
#15 |
#16 |
you will need a new driveshaft for the turbo400
#17 |
cdowns- Thanks, I wasn't sure if I could shorten it or if I would need a new one.
#18 |
I believe the yokes are different.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#19 |
i had to shorten mine about 3 inched if i remember right, i never hooked up the detent switch back then, and i had to find a thick walled yoke,
#20 |
Lattimer- Thanks
bigmac73- thank you for the info
#21 |
Lattimer- Thanks
#22 |
![]() Join Date: Dec 2012
My line of thinking is this. A TH350 is a great tranny in a light low geared car/truck. You may also consider a BUILT 700R4. I had one behind a 431 cu. in. Olds for quite a while. It didn't get hammered all the time but it did have some torque pushed to it. I used to boil 12x33x15 MS tires with it in the truck. The 700 is still in one piece. I attribute that to the big @$$ cooler that was installed with it.
I hope I didn't jynx it.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#23 |
Longhorn70- I appreciate the info. I was planning on getting a 454 from a motor home as I have read on here where many had done so with good results. I do tend to be throttle heavy in my 89 with a 350, but I would have to me more careful with a big block local cops seem to love pulling over teenagers driving trucks
