Re: 355 cu in and 700r4
Slow-1,
Any chance you know what mpg you are getting with that combo? I have the same set but in a 69 step and was thinking of going to an overdrive. Thanks, Jim
Thanks, Jim - 69 Short Step CST 350 AC/PB/PS - 69 Short Step 307 Man Column/PS |
![]() Join Date: Apr 2010
Just removed the metering rods and found there is no spring for the driver side rod. Also the 2 rods are different sizes. This was suppose to be a new carb.
#3 | |
Dang...did you buy it new?
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
I bought the whole engine in pieces from a guy. Every thing was new or rebuilt and I had to put it together. I would have never thought that a spring was causing all these problems. Are both metering rods suppose to be the same size? Thanks for all the help.
I have no experience with Edelbrock carbs.
I would start a new thread about it to see if you can get someone who knows them to help you.
Yes, both should be the same.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
![]() Join Date: Oct 2011
What tire size are you running?
...noting that the bigger the tire the worse this situation becomes. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
I am running stock tires. I think the whole problem is the metering rods and springs. Ordered the set today so now can't wait for them to get here.
I have not checked it since my last engine rebuild but was getting 17 to 18 the last time I checked...which was probably right after I put in the trans 11 years ago.
I drive it a fair amount and seem to need gas at the same intervals as my wife who drives a Honda Pilot (20 gal tank and 17-20 mpg).
