Another Day, Another Dollar
HEI guys I need an opinion
I was doing something under the hood completly unrelated and nowhere near my carb when I noticed my main HEI power lead (red 8ga from fuse block) had a really sh*tty bare and green spade connector on the coil end. I cut and replaced the end and when I fired the truck up the next day it seems my idle is 500 or so Rpm higher than it was before.
Is there any conceivable notion that having a stronger spark could bump my idle up? I checked my throttle linkage and it is not hanging up or sticking. I haven't been anywhere near the carb lately. It's a 600cfm edelbrock with mechanical secondary if it matters
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
![]() Join Date: Oct 2006
Re: HEI guys I need an opinion
was the distributor loose? You may have advanced the timing slightly...
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
It's possible I guess. But that's a pretty good bump for just a better connection.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Dizzy isn't lose. It seems to start easier too. Hmmph. Ill report back as I find more. I'm almost tempted to crimp the crappy end back on to see if it reverses the effect
#5 | |
I could see that happening, a "bad connection" does not necessarily mean no connection at all. It could cause all kinds of problems, hard starting, missing, etc.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Must have been crap stuck in the carb because it levelled back out after an hour or so of driving
