Old 11-04-2013, 06:17 PM   #1
Lattimer
Lattimer's Avatar
Re: 355 cu in and 700r4
Originally Posted by gysgtc View Post
I bought the whole engine in pieces from a guy. Every thing was new or rebuilt and I had to put it together. I would have never thought that a spring was causing all these problems. Are both metering rods suppose to be the same size? Thanks for all the help.
Yes, both should be the same.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 11-04-2013, 06:23 PM   #2
Coley
Coley's Avatar
Smile Re: 355 cu in and 700r4
What tire size are you running?
...noting that the bigger the tire the worse this situation becomes.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 11-04-2013, 06:41 PM   #3
gysgtc
I am running stock tires. I think the whole problem is the metering rods and springs. Ordered the set today so now can't wait for them to get here.
gysgtc is offline   Reply With Quote
Old 11-04-2013, 06:42 PM   #4
gysgtc
Thanks Shawn.
Old 11-05-2013, 07:16 PM   #5
gysgtc
Just got the metering kit and put in the rods and springs and it runs like it should. Now I'm going to play with different rods and springs.
Old 11-05-2013, 09:09 PM   #6
slow-1
slow-1's Avatar
Cool...now you can see how it does and then decide on swapping gears...glad you got it figured out.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 11-05-2013, 09:48 PM   #7
Lattimer
Lattimer's Avatar
springs are depending on how much vacuum your engine makes. The strongest ones are for stock vac, weaker ones get swapped in as vac goes down. I think below 10" or so you need to go to a lighter spring.
The rod sizes are the first way to change rich/lean mid-throttle. If your plugs are white go a size smaller on the rods, if they are dark go a size bigger.
If you can't get them to be tan changing rods, then you need to change jets.
Shawn
Old 11-06-2013, 05:55 PM   #8
gysgtc
Thanks Lattimer.
