![]() Join Date: Apr 2010
Re: 355 cu in and 700r4
Thanks Shawn.
Just got the metering kit and put in the rods and springs and it runs like it should. Now I'm going to play with different rods and springs.
Cool...now you can see how it does and then decide on swapping gears...glad you got it figured out.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#4 | |
The rod sizes are the first way to change rich/lean mid-throttle. If your plugs are white go a size smaller on the rods, if they are dark go a size bigger. If you can't get them to be tan changing rods, then you need to change jets.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Thanks Lattimer.
