Found in Cowl
took my cowl off to sand and paint it and put in a screen. Found this wrench and some kind of flapper door. Not sure how the flapper door got in there.. Doesnt look like it goes anywhere under the cowl, but I dont see a spot in the cab for it either.
Im going to sandblast the wrench and add it to my collection ![]() |
Re: Found in Cowl
That's the AC air diverted, 70s version of recirculate. It goes in the cowl area, has a rod that screws into a plastic clip on the interior side and the other side has a rod that hooks to a vacuum actuator in the engine compartment near the air box above and right of the blower motor.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Moderator
![]() Join Date: May 2007
Re: Found in Cowl
That allows fresh air into the cab when the heater is on. With the heater on and AC off it is open. When the AC is on, it is closed and the recirculation vent is open on the passenger kick panel.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 11-04-2013 at 09:06 PM. |
Re: Found in Cowl
hmm I don't see ho wit sits in there. Ill have to dig out a flashlight and the lmc catalog and see if I can piece it together.
Is there some kind of under coating sprayed inside the holes in the cowl where the tunnel for water is? Looks like mine has something there. |
