5.3 intake flap question
Hi all,
Is the throttle body flap supposed to move when the ignition is in the ON position but not started? My flap seems like it wants to move when the gas peddle is pressed but barley budges, is this normal? There is also a high wine coming from somewhere on the engine when the ignition is in the on position?? any thoughts?? |
Re: 5.3 intake flap question
It's probably some kind of startup check to verify the position of the tb.
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
#3 | |
meowMEOWmeowMEOW
What kind of whine? Key on but engine off? Fuel pump will make noise, dbw components make an electric motor noise for a couple seconds.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thanks for the replies guys!
Yes, the truck is DBW, so the flap should move when the ignition is on but engine not running? This was supposed to be from the same vehicle, how do I check to see if the pedal is from the truck?? Hart Rod, thanks for the info on the whine, thought I was going crazy! PCM is back at the tuners shop, we will see what happens when he sends it back. |
meowMEOWmeowMEOW
The flap would move on its own briefly, yes. If its moving all over the place after that little check, then there is an issue.
Have you cranked the truck over? A dbw mismatch might not be 100% evident until you try to apply pedal input with the truck running. Sometimes it will even allow a few sweeps on the pedal, before dropping itself into a dbw mismatch code (there are a few different ones). I initially had a later model pedal on my truck, and it allowed me to rev once or twice before going limp.
#7 | |
Also, does anyone know if the 2011 5.3 came with EGR?? Thanks again guys! |
Here is a pic of my pedal
![]() ![]() and the wires going into the pedal ![]() This is supposed to be the pedal it came with. |
meowMEOWmeowMEOW
You could have at least put the pictures right side up.....
![]() That is the part number for the 07+ trucks, so at first glance it would appear right to me.
High pitch whine is tranny. 6l80e right? If so it's the TCM.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
