'68 Fuel Issue
I have a 1968 C10 with a 350 V8 and after it sits overnight the clear fuel filter between the carb and pump is bone dry. For some reason the fuel is running back thru the pump. Do I have a worn out fuel pump or is this normal?
Re: '68 Fuel Issue
I quit using glass filters on vehicles long time ago but as I recall this is normal.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: '68 Fuel Issue
Normal as far as I know. The fuel in your float bowls supply the gas for the couple seconds it takes for your pump to fill the line again
![]() Join Date: Dec 2012
Re: '68 Fuel Issue
get rid of glass filter Fire Hazzard
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
Active Member
![]() Join Date: Jul 2007
Re: '68 Fuel Issue
Pretty normal as mentioned above but just to make sure pump isn't leaking, look around the pump for signs of fuel stains and maybe check the oil to make sure there's no fuel smell. If you're having trouble starting in the morning, there may be other issues involved.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
