Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-01-2013, 08:05 AM   #1251
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Junkyard Jimmy Super Low Buck Build Thread
Originally Posted by badpeanut View Post
Your heater core connections are reversed compared to mine and what is shown here (see automatic trans figure): http://67-72chevytrucks.com/vboard/s...7&postcount=18
I know. I have the service manual and know how they are supposed to be.
hgs_notes is offline   Reply With Quote
Old 11-01-2013, 07:41 PM   #1252
swamp rat
swamp rat's Avatar
+2 I see this a lot too, plus the heater core inlet and outlet are different sizes. So if the core is mounted upside down i imagine it could lead to a problem. Actually that whole thread is worth the read, good info.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-01-2013, 09:51 PM   #1253
hgs_notes
GEARHEAD
hgs_notes's Avatar
Badpeanut, the reason I plumbed it this way was just cuz it looks better. There are pro's and cons either way. I appreciate you pointing out the difference though. If someone was gonna use mine as a guide they might not like that it's non-stock.
Old 11-06-2013, 11:51 AM   #1254
hgs_notes
GEARHEAD
hgs_notes's Avatar
Its a handful on the ice. Fun in the snow.
Old 11-06-2013, 01:37 PM   #1255
Low Elco
Ha Ha! Wheeeee! 4x work good?
Low Elco is offline   Reply With Quote
Old 11-06-2013, 01:52 PM   #1256
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
YeeeeeeHaaaaaaaaa!!!!!!!!!!!
Might be coming up there soon for work, can't wait to see some snow this winter!
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 11-06-2013, 02:32 PM   #1257
hgs_notes
GEARHEAD
hgs_notes's Avatar
I didn't shift it to 4 high until after the picture. It was sloppy wet snow and while I could make progress as a 1 wheel wonder it was easy to pull back on the shifter and pop it into a front/rear 2 wheel wonder. I desperately need to bleed the rear brakes.
You be sure to look me up. I'll PM you my contact info.
Old 11-06-2013, 04:04 PM   #1258
Dale99
I dont miss that white stuff at all.
Dale99 is offline   Reply With Quote
Old 11-07-2013, 12:23 AM   #1259
hgs_notes
GEARHEAD
hgs_notes's Avatar
A couple of things that came up today were that I had a hell of a time starting it and the rear brakes were not grabbing at all (well I knew that last part a while ago, makes for ez brake stands).
I was having some trouble with it sputtering the past couple weeks and then double checked that the manual choke was actually opening and it wasn't. Popped it open and it's running like a champ again. Then today it would not start. It had been flooding with the choke issue so I checked again and sure enough, the cable is binding and keeping it shut too far. If I pull to hard shut it binds up and won't open, so I'm gonna try using some marks on the choke knob shank as a reference.
The brake issue I thought was just that they needed bled again. But while looking things over I found the adjuster on the pass side had popped out of its slot. So I got that back into position, readjusted the pads on both sides, bled the lines again just because, and gave it another test drive...
Test drive SAT. (Abbreviation for satisfactory)
Took it out through a cornfield on the south edge of town. Drove it like I stole it.
Old 11-07-2013, 01:14 AM   #1260
swamp rat
swamp rat's Avatar
OMG its dirty!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-07-2013, 10:40 AM   #1261
Dale99
clean it quick, otherwise that crap wont come off.
Old 11-07-2013, 01:29 PM   #1262
jaros44sr
jaros44sr's Avatar
Wow, wish mine looked like that....theres a truck being used properly, nice pics
Wonder if i could paint faux dirt on my truck lol
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-07-2013, 02:04 PM   #1263
Low Elco
AAAAAAK! It's dirty! Right on! Glad the brakes were an easy fix!
Old 11-07-2013, 07:00 PM   #1264
hgs_notes
GEARHEAD
hgs_notes's Avatar
Originally Posted by swamp rat View Post
OMG its dirty!
It had a sore spot so I rubbed some dirt in it.
Kinda like when I was making that face and it stayed that way? My plan was to let it dry and then flake off. Just the beginning of my protective layer so rocks flinging off the tires don't scrath my paint.
Thanks, and don't you dare think about faux dirt. That's something some wanna-be would do and would justify immediate forfeiture of your "man card". Just do like I did. Step 1-Build it, step-2 fix it, step-3 test drive it, repeat steps 2 and 3. If you feel step-2 is not required, then step-3 wasn't done properly.
I'm glad they were too. It was about 1 minute of bliss pounding through the cornfield.
I'm getting to the point where I'll have to tear more stuff apart to "finish" it. Gotta pull the rear seat out and the wheel tubs to reseal those and get the bed liner done in the back. I need to do a little cutting and welding to get the roll bar mounted the way I want. Fix the driver side seat mounting (needs a spacer to lift it and more permanent bolting), still need to change lube in the diffs, install the electric fan, fix a few wiring glitches, hook up the stereo (low priority) replace some headlights, replace plug wires, fix gas tank fill hose, fuel gauge, and then decide which way I'm gonna go with bumpers and start working on those.
I have doubts that I will start the suspension changes this winter. And honestly, I'm in no hurry to jump into that. I'm having way too much fun driving it. Can't stand having a laid up vehicle. I have a bunch of vacation days to use up before the end of the year. I have some house projects to tackle but I know there will be several garage days in there too.
Thanks again for the support/encouragement I have received from my fellow gear heads.
Old 11-16-2013, 12:34 AM   #1265
Tynee
I miss this truck.
Tynee's Avatar
Awesome, isn't it great getting to drive it?
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 12-04-2013, 09:58 PM   #1266
hgs_notes
GEARHEAD
hgs_notes's Avatar
Yes it is.
Finally got back to work on this thing. I went out to the garage and saw that the front left tire was low. So I aired it up and took it for a test drive...
Old 12-04-2013, 10:02 PM   #1267
hgs_notes
GEARHEAD
hgs_notes's Avatar
Test drive was satisfactory.
That is all.
Old 12-04-2013, 10:22 PM   #1268
turp mcspray
turp mcspray's Avatar
I remember full throttle, cookie fun in my orange blazer. Fun times!!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-04-2013, 11:09 PM   #1269
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Nice pics! Hows the heater work Looks like Sleepy Eye got more snow that the south metro here!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-04-2013, 11:21 PM   #1270
hgs_notes
GEARHEAD
hgs_notes's Avatar
My tires are crap for snow. In 2wd it will barely move.
We got a good 8" or so and I wanted to get out and enjoy it today before it gets cold. My kids got out early from school today and my son came in asking to take it out.
Glad we didn't get hit like NE MN did. The arrowhead region had 2' this morning and were expecting another foot. I think the snow is here to stay this time.
Here's some video of the fun. I freaking love driving this thing.
Old 12-05-2013, 10:30 AM   #1271
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Damn... That LOOKS COLD. Im digging my heated Garage..LOL
Tom Vogel is offline   Reply With Quote
Old 12-05-2013, 11:04 AM   #1272
Low Elco
Yeeee-Haw!
Old 12-05-2013, 08:24 PM   #1273
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Wow...I must be a wuss, I got cold watching that...but...it looked like fun!!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-05-2013, 09:33 PM   #1274
Bomp
Bomp's Avatar
Built for FUN.
Ain't no garage queen
Bomp is offline   Reply With Quote
Old 12-05-2013, 11:20 PM   #1275
hgs_notes
GEARHEAD
hgs_notes's Avatar
Looks colder than it was. It was almost 30F out. Barely cold enough to snow. I wanted to get out in it yesterday cuz the real cold was moving in. I think our high today was about 6F.
BTW, my garage is heated too. That heater was by far the best spent money in the entire garage.
Yeeee-Haw!
Hick
It was a blast. I wanna see how it handles deeper snow, once we get it. Nice thing about the GMC is the all steel grill for busting drifts. Can't do that with a 71-72 blazer without busting the egg crate.
Single digit highs and below zero lows for the next several days. I figured if I was on a snowmobile I'd be in the open, so no top for me. I had my heavy coat on, and knit hat, and gloves. The heater was on. The boy and I were just fine.
Originally Posted by Bomp View Post
Built for FUN.
Nailed it.
It's gonna need a rear locker at least though. Spools are much cheaper. Need to do some parts searching. I used a lock right on my C-10. It's a bit cheaper than replacing the full carrier and it's easy to install. Need to find a bargain though, money is tight.
