Old 12-12-2003, 01:05 AM   #1
veltex
veltex's Avatar
HEI clearance
If I switch to HEI are there any clearance problems? I know there is room once installed but, on my BB when putting in the points dist the rotor had to be removed to squeek it in.
veltex is offline   Reply With Quote
Old 12-12-2003, 01:07 AM   #2
dinnut
dinnut's Avatar
i think hei is a little taller than a points type setup if it has the build in coil but i really dont know.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-12-2003, 01:17 AM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
HEI is taller and wider. No clearance problems on a SBC installed in the correct V8 position, but i dunno about big-blocks....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-12-2003, 02:16 AM   #4
junkyardjohn
junkyardjohn's Avatar
NO CLEARANCE PROBLEMS AT ALL. SMALLBLOCKS IN THE 6 CYL. POSITION WILL CLEAR THE FIREWALL JUST FINE, ALTHOUGH YOU DO HAVE TO REMOVE THE CAP FIRST. BIG BLOCKS IN THE V-8 POSITION & ALL MOTORS IN 4WDs FIT GREAT TOO. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-12-2003, 08:54 AM   #5
GMC Jim
GMC Jim's Avatar
installed GM delco HEI dist on my 402.BB... no clearance problems............ JIm
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
