Garage Queen Material
tooth of flywheel?
how many teeth will i need on my flywheel?
Robert Olson Transport
![]() Join Date: Oct 2002
all of em
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
You get what you pay for
![]() Join Date: Dec 1999
Depends on which starter you use. With the offset bolt holes in the starter nose, like your 305 has, you would need the 14" 168 tooth flexplate. I can't remember if a 71 block will work with offset starters or not, but with a straight across bolt pattern on the nose it uses a 12-1/2" 153 tooth flexplate.
Mike 1985 Chevy C-10 |
and any of them should work fine with my th350c?
#5 | |
if it was a '71 block, what would i need?
No a 168 tooth is not normal, or what you think is normal.
Most all small blocks are drilled and tapped for both starters. I have had many small blocks with straight across bolt patterns. But, not every small block will have both patterns. I suggest you wait until you see what the block you use has. A lot of the older blocks only had straight across patterns. I know this because I'm old and have changed many starters in my days. ![]()
#8 | |
You are wrong. :p
Ask the builder, the small blocks can use either straight or stagger at least my block is that way.
and do yourself a favor, get it lined up to be sure while it's on the engine stand, or cherry picker before you put it in. or just buy a mini starter with multiple mount positions for 153 or 168, thats where I am heading now. Last edited by Nvbowtie; 12-12-2003 at 10:37 AM. |
