Gauge cluster upgrade
My truck came with the basic cluster ( speedo and gas). The PO install three aftermarket gauges under the dash (volt, temp, and oil).
I want to install a stock cluster that includes the volt, temp, and oil. I know I'll need to replace the temp sending unit with this http://www.americanautowire.com/shop...ding-unit-5032 Will I need to do anything else or should the volt and oil be plug and play? |
Moderator
![]() Join Date: May 2007
Re: Gauge cluster upgrade
You will need to modify your existing wiring as well. Gmcpauls website has detailed instructions on how to do it. This came up recently here as well, but I can't seem to find the thread. The oil gauge is mechanical and you will need a hard line for it. Post a wtb on the parts board and I'll bet randy or someone else has one for sale.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#3 | |
Thanks for the help. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
See if this helps, it's a long thread but it is very informative.
........http://67-72chevytrucks.com/vboard/s...d.php?t=564505
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#5 | |
Thanks! |
#6 | |
Cluster King
![]() Join Date: Nov 2012
Thank you, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
I needed this information as well... Saving this post.
71 swb 350/4sp manual 5/7 static drop |
#8 | |
![]() cheers JohnG |
Will this work on my cluster?
http://www.ebay.com/itm/1969-75-CAMA...-/350535840207 |
#11 | |
Old member
Small screw driver pushed in from opisite direction of wire. The metal clip has a tang on it. Depress it and pull it out by the wire.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#13 | |
Cluster King
Good information from Andy on removing the terminals from the connector.
Thanks guys. Going to stop by the auto parts store today...
#15 |
If you haven't bought your temp sender yet, I just bought mine from www.lectriclimited.com. Found them searching for temp gauge info on here.
#16 | |
#17 |
I bought my mechanical oil gauge copper tube and fittings from Classic Parts. It works great on my 1981 and will fit 67-72.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
#18 |
Having a hard time finding this adaptor. The small size thread is 5/16-24.
Does anyone know that the gauge cluster thread is? |
#19 |
I know that changing those pins has to work, but it didn't for me. I put a cluster in my 68 GMC that was a brand new [rebuild] by a member on here that does real nice work. I followed the instructions to the T and even took more time than I should have doing it. I had a different cluster plug and changed over to and used some pins from it to the ones that had to be added. When I got done all that worked was the speedo and it made a noise every time it came to a 0 on the tenths side! I only drove it about ten miles after I put the tac/vac in it [and a tilt at the same time] but it is next on the list to come to the shop for frame-off/swap rebuild as a short truck any way.So maybe then I will get it figured out. I have another truck in the shop now plus another inline to be built, and I have tach dashes for them all So maybe I can find out what my problem is/was with the other. I know it has been done to death, other have done it right? Jim
#20 |
#21 |
What does the clip that connects to the temp sending unit look like?
