Old 11-07-2013, 01:10 AM   #1
preacher anthony
Smile 200r4
Has anyone installed 200r4 in C10? I have a '72 Super Deluxe shortbed w/ 350/350 combo. I have a friend giving me a 200r4 out of a '86 Pontiac 2plus2.
preacher anthony is offline   Reply With Quote
Old 11-07-2013, 01:26 AM   #2
AustinScott
AustinScott's Avatar
Re: 200r4
We have one in our truck,(200-4R) seems to be doing just fine so far....
Alot of install images of the transmission in our Google albums...
Any questions feel free to ask...
Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 11-07-2013, 03:01 AM   #3
preacher anthony
Re: 200r4
Thanks, all your info is useful. I have a quadrajet, will I have to change any linkage for carb?
Old 11-07-2013, 06:51 AM   #4
myyamr7
myyamr7's Avatar
Re: 200r4
I used the same location on the carb that the TH350 cable was hooked to, just had to change the pin to a clip type for the 200-4R cable to clip to. Just make sure the cable is 100% tight at full throttle
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 11-07-2013, 08:44 AM   #5
MARKDTN
Re: 200r4
A 200R4 is an OK transmission, but will not hold up to high power in bone stock form. Keep in mind that GM never put one behind a big-block. The biggest stock engine in front of a 200R4 was a "mighty" 307 Olds. If you have it rebuilt with some of the upgrades it will be fine. If you want an overdrive and don't want to build it first, better get a 700R4. You can get a carb bracket for the TV cable from the car it was in or a Monte Carlo in the same year ranges. DO NOT install a 200R4 or 700R4 without hooking up the TV cable before you ever start it.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-07-2013, 10:43 AM   #6
Keith Seymore
Keith Seymore's Avatar
Re: 200r4
Technically, that's true - but the 200R4 was used in the Buick Grand National, which was a higher performance application than either of those.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-07-2013, 10:57 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: 200r4
I put one in my Suburban, behind a 350 crate engine. I pull the trailer with it but the heaviest thing I have hauled so far is a complete 3/4 ton frame. I used the BowTie Overdrives TV cable kit and lockup kit. It just turned over 3000 miles and no problems so far.
LockDoc
Leon
Old 11-07-2013, 12:12 PM   #8
1968k10blue
1968k10blue's Avatar
Re: 200r4
LockDoc
Hey lockdoc, completely off topic, but I just read your signature for the 100th time and noticed you spelled marriage wrong just thought I would let ya know!
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 11-07-2013, 12:22 PM   #9
MARKDTN
Re: 200r4
K
True, the GN was the highest performance application stock, but they don't last long in a GN with any kind of tires that will hook. The 200R4 in stock form is not all that strong. They do require a rebuild to use much power or you will shatter the insides. They were never used in a Corvette with the CrossFire (205HP/290 Torque) which was about the same power as a stock GN (200HP/300 torque)-much less a 250HP TPI Corvette. The reason why is that the Corvette had wider, stickier tires and would hook up; the GN did not. Now of course a GN can be built to put the power to the ground, but then you run into rearend issues. If you overcome those then the transmission comes into play. That is why the Corvette got a 700R4 and the GN got a 200R4 even though both had a 3.42 axle ratio.
I'm not saying don't use a 200R4. I am saying that it might not last long if you take a used one out of a tired V6 or 305 A-Body and put it in a heavy truck with a 350/350 and trounce on it.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 11-07-2013, 01:21 PM   #10
68K30
Re: 200r4
Everyone always talks about the 2004R being so strong because it was in the Grand National, the real reason GM used the trans is that it was the only overdrive trans they had that would bolt up to the Buick block, not because it is an amazing trans.
68K30 is offline   Reply With Quote
Old 11-07-2013, 01:47 PM   #11
Stickman
Stickman's Avatar
Re: 200r4
LockDoc
X 2 on the Bowtie Overdrive
Stickman is offline   Reply With Quote
Old 11-07-2013, 02:03 PM   #12
orbframe
Re: 200r4
x3 bowtie overdrives... used them before and i've just ordered another 200-4r with all their accessories (crossmember, tv setup, lockup wiring) for my 1968 with a 350 smallblock.
bowtie overdrives and other builders modify/beef up the 200-4r to respectable/usable/reliable performance levels.
orbframe is offline   Reply With Quote
Old 11-07-2013, 02:09 PM   #13
Stickman
Stickman's Avatar
Re: 200r4
Originally Posted by orbframe View Post
ugh double post
And there customer service is outstanding .
Old 11-07-2013, 02:44 PM   #14
LockDoc
LockDoc's Avatar
Re: 200r4
Well, I don't read it a lot but you would think I would have noticed it for as long as I've had it on there...
Thanks for the heads up.
LockDoc
Leon
Old 11-07-2013, 03:06 PM   #15
1968k10blue
Re: 200r4
I know right? I have read it at least a dozen times cause I always think it is a perfect saying anyway back to a 200-4r transmission
Austin
Old 11-07-2013, 07:41 PM   #16
preacher anthony
Re: 200r4
Thanks everyone. I will check on the kits. I knew I would have to add something for the lockup. I can't get my hands on a 700r4 right now, $$ is tight. I'm a "state" employee, elementary school counselor and Driver's Ed. instructor. The 200r4 is free, so my only cost will be the two kits mentioned. I'll check with my friend about a carb bracket. He has owned over 20 of the '86 Grand Prix 2+2's, so I know he has one somewhere. My 350 is stock and I don't plan on doing any upgrades. I would love to have a 5.3 at some point.
Old 11-07-2013, 07:57 PM   #17
LockDoc
LockDoc's Avatar
Re: 200r4
With the Bowtie TV kit you get a bracket.
LockDoc
Leon
Old 11-07-2013, 10:29 PM   #18
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 200r4
had a 200-4r in my truck before the 4L85e. Mine wasn't built strong enough to handle my motors torque/horsepower even tho it was supposed to be. Was OK in 1st and 2nd, but couldn't handle 3rd at WOT. That said....built properly they are a great choice for these trucks...will fill the spot a turbo350 was quite nicely.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-08-2013, 08:13 AM   #19
MARKDTN
Re: 200r4
You don't need a kit if you want to do this cheap. If your friend has a carb bracket for a Q-jet and he gives you a TV cable and the torque converter bolts then you have the hardware for the basic installation. You can use your crossmember and slide it back if necessary, but it should fit without moving. Then for lockup go buy a kit from BTO or Painless (or Ebay) or if your friend has any cars left see if you can get what you need. All you need is a vacuum switch, a brake switch, a 4 pin square weatherpack plug, and a few pieces of wire. A non-computer A-body probably has this as a sub-harness that you can easily get. One other thing, there may be difference in a floor shift and column shift linkage on the side, you may have to find a column shift plate if it doesn't have one.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 11-08-2013, 11:03 AM   #20
preacher anthony
Re: 200r4
Thanks Markdtn, grateful for everyone's advice.
