Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 08-06-2013, 11:49 AM   #1
draggin49
meguiars cleaner wax???
My truck is in the original paint from 1969, has some stains , oxidation etc, im leaving the paint, but was curious if this is something I should use on the entire truck???its my first old vehicle im leaving the patina in place so figured id make sure before I go messing it up
In the pics you can kinda see some of the discoloration, almost a haziness
draggin49 is offline   Reply With Quote
Old 08-06-2013, 11:57 AM   #2
Prematuregrey
Prematuregrey's Avatar
Re: meguiars cleaner wax???
Good stuff, I've used it for over 20 years now and never had an issue. I started using it when I worked at a detail shop in N.C., it was all they used unless we did a rubbing compound. Then we would use their 3 step combo after the compound. If you really want it to shine, go with the 3 step.
Owner: Times Are Tough Toys
92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it.
89 Mercedes 560 SEL, Merdle. Wrecked
71 Chevy K20, Clifford, BB and 1 Tons
Prematuregrey is offline   Reply With Quote
Old 08-06-2013, 12:08 PM   #3
Lee H
Lee H's Avatar
Use it, you will be amazed.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 08-06-2013, 12:19 PM   #4
draggin49
Awesome, excited to try it. This can just be applied by hand correct??
Ill take some after photos for comparison sake
Old 08-06-2013, 12:51 PM   #5
asolde
asolde's Avatar
I used it on my 72 and it worked great.
asolde is offline   Reply With Quote
Old 08-06-2013, 02:46 PM   #6
DGulliver
DGulliver's Avatar
+1 on the cleaner wax, you'll love it.
Also, you'll get better/faster results with one of those $30 "wiggler/vibrating" type polishers from the parts store. (A real 'buffer' takes good tecnique and would probably remove too much paint for your intent.)
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8
'74 Trans Am 400, '80 Trans Am Indy Pace Car
Mercedes AMG S55, SLK230 Kompressor, GL450
'96 Dodge Indy Ram Official Indy Truck
'99 Porsche 911 Carrera
DGulliver is offline   Reply With Quote
Old 08-06-2013, 03:14 PM   #7
SuperC10Tex
SuperC10Tex's Avatar
I like Maguire’s cleaner wax, but try 3M rubbing compound to really get off some of that oxidation/discoloration. Pic below of doors and hood are right after using 3M....that is original paint!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 08-06-2013, 04:22 PM   #8
JOJABOY
Try Color Back made by Turtle Wax
Turtle Wax T-270R1 1-Step Color Back Oxidation... Turtle Wax T-270R1 1-Step Color Back Oxidation...
This is by far the best product ever made by Turtle Wax. It doesn't require a ton of elbow grease. Just several towels. Just rub it on and then rub it right back off. It will clean ALL of the oxidation off and will leave your original paint looking great. It really is amazing how fast and easy this stuff works. You will have to wax your truck right after using this.
JOJABOY is offline   Reply With Quote
Old 08-06-2013, 04:35 PM   #9
JOJABOY
Old 08-06-2013, 09:22 PM   #10
blazercrazy70
blazercrazy70's Avatar
I used it worked great need to follow up with their good wax to make it really shine.
blazercrazy70 is offline   Reply With Quote
Old 08-07-2013, 12:28 AM   #11
2ndstoryslam
2ndstoryslam's Avatar
Man I could have this truck shine in two days if you were near by, Here is a link to remove as little paint as possible to rejuvenate the single stage factory finish. It works I did my '61 Bubbletop last weekend. And a cool green metallic '73 Buick the week before. The cleaner wax will take forever with what you have. A pro with a foam pad and 3M #6065 could quickly graze the surface you have. Then rub in by hand Meguiers #7 glaze, several times leaving on overnight. The video is priceless.
2ndstoryslam is offline   Reply With Quote
Old 08-07-2013, 04:50 PM   #12
draggin49
Not done yet, didnt have tools just by hand, quite an improvement though.entire truck was super dull/hazy
Old 08-09-2013, 12:45 PM   #13
leddzepp
Moderator
leddzepp's Avatar
Meguiars Ultimate Compound works great IMO.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-08-2013, 05:24 PM   #14
Malo83
Cruzzzn' Vet
Malo83's Avatar
X2, this will give better results than a cleaner wax
Malo83 is offline   Reply With Quote
