Old 11-01-2013, 06:56 PM   #1
Vova
Ford gas tank
Who's using one of these tanks in their c10? I like the low profile and I think it would fit inside the frame rails with a little trimming.
http://www.mustangdepot.com/OnLineCa...fuel_tanks.htm
Vova is offline   Reply With Quote
Old 11-01-2013, 11:51 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Ford gas tank
I don't think we use the "f" word here.
Seriously, it looks like it'd be a good fit.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 11-02-2013, 12:13 AM   #3
Vova
Re: Ford gas tank
I was waiting for that...
Old 11-02-2013, 02:31 AM   #4
jorgensensc
jorgensensc's Avatar
Re: Ford gas tank
I just so happen to have one outside and out of the car (I'm working on a '66 mustang for a customer). I'll measure and let you know tomorrow. The fuel sending unit mounts on the bottom side, if that bothers you at all.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-02-2013, 02:33 AM   #5
Vova
Re: Ford gas tank
Shawn
That would be great. I like how flush it sits and doesn't hang down too low.
Old 11-03-2013, 04:23 PM   #6
55metalmonkey
Re: Ford gas tank
Vova,
As requested I did a writeup on my mustang fuel tank/ sending unit solution. I posted it in the 47-59 section since that is my usual hang out and didn't want to double post in different sections,
the link is here: http://67-72chevytrucks.com/vboard/s...=1#post6346101
Hope this helps and if you have any questions feel free to ask
55metalmonkey is offline   Reply With Quote
Old 11-03-2013, 11:14 PM   #7
Vova
Re: Ford gas tank
Thanks man. I'm going to give it a shot...
Old 11-03-2013, 11:53 PM   #8
jorgensensc
Re: Ford gas tank
I'm really sorry. I got very sick today and wasn't able to get that info for you. I will try and get the dimensions tomorrow for you.
Old 11-03-2013, 11:57 PM   #9
Vova
Re: Ford gas tank
No worries. Hope you feel better.
Old 11-08-2013, 01:50 PM   #10
55metalmonkey
Re: Ford gas tank
Vova,
If you check this thread:
http://67-72chevytrucks.com/vboard/s...tang+fuel+tank
The 16th post down has just about every measurement you might need
Old 11-08-2013, 02:42 PM   #11
Vova
Re: Ford gas tank
Originally Posted by 55metalmonkey View Post
Vova,
Yes I found it after porting the tread. I think I'm going with the Ford tank. I like that it doesn't hang down too low.
Old 11-08-2013, 06:51 PM   #12
In The Ten Ring
Re: Ford gas tank
If it works then do it!
In The Ten Ring is offline   Reply With Quote
