Old 12-12-2003, 01:20 AM   #1
72MARIO
72MARIO's Avatar
Will 8" rallys rub ?
I was hoping to run my 8" rallys for the summer because I don’t have a lot of extra money for rims. I will eventually get 17" all around but right now I just want to get it on the road. So what I have is a 2.5 drop spindle and a 1" coil. I am worried about rubbing problems. What tire size should I run? I want there to be a bit of side wall if possible. Just looking for opinions and for the guys out there who have run this setup.
I don't want to rub off My new gloss Black paint on my inner fenders either.
Thanks Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-12-2003, 01:31 AM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
I don't think they will rub but a can't say for sure.
A good tire size is 255/60-15. They look great on an 8" rallie. Or even 275/60-15 if you want them a little bigger.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-12-2003, 01:37 AM   #3
72MARIO
72MARIO's Avatar
I want a huge tire on the back. I am going to need all of the traction I can get. I was thinking of a 295 for the back.
2005 TAHOE DD
Old 12-12-2003, 01:38 AM   #4
dinnut
dinnut's Avatar
im running 255/60-15's on my truck.
i think the wheels are wide though--- putting it on a not so wide wheel will make it not so wide
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-12-2003, 01:40 AM   #5
lukecp
lukecp's Avatar
295's will look kinda funky on a 8" rim....you will proably want to go with a 10" rim for a tire tht big.
Old 12-12-2003, 03:36 AM   #6
Hooter
My other Love
Hooter's Avatar
im running 15/8 stock rallyes with 265's all around with no problems and that is with the front lowered 2.5 inches
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-12-2003, 03:36 AM   #7
Hooter
My other Love
Hooter's Avatar
pictures of my life
Old 12-12-2003, 04:30 AM   #8
70short
I have never had tire rub. Even when I am turning A corner and pulling A curb at the same time. I want A 4/6 drop. and I will use the same combo And I would say that I wont have A problem with rub.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-12-2003, 05:41 AM   #9
PR454SS
PR454SS's Avatar
Re: Will 8" rallys rub ?
[QUOTE]Originally posted by 72MARIO
[B]I was hoping to run my 8" rallys for the summer because I don’t have a lot of extra money for rims. I will eventually get 17" all around but right now I just want to get it on the road. So what I have is a 2.5 drop spindle and a 1" coil. I am worried about rubbing problems. What tire size should I run?
I'm running a 255/60/17 on the front of my 72 with a 3 inch drop and not seeing any problems with rubbing, mine hits the bumpstops before it will rub
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 12-12-2003, 07:22 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm down 4.5 inches in the front with 8 inch rally wheels. Tires are 245/60/16 front and 275/60/15 rear.
You will not rub with a rally.
My truck had a 6 cylinder in it in this picture, so it's not too low. Big block swap this month will lower it some more.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-12-2003, 11:24 AM   #11
72MARIO
72MARIO's Avatar
I was planning on taking my rear rims to a Race Shop. They will widen the rims up to a 15" wide for 150 dollars. I think it would look pretty cool.
2005 TAHOE DD
Old 12-12-2003, 12:26 PM   #12
miket
miket's Avatar
You shouldn't have any problem running 295/50-15's with your drop...but you need 10" wide wheels. Kinda hard to see....
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 12-12-2003, 03:10 PM   #13
MITCH1914
MITCH1914's Avatar
i am running the BFG drag radial 325-50-15's on 15x8 rallys with at standard backspacing. i do have a small 1/8 spacer place for a little extra space. it will work. i run my truck at IRP here in indy.
MITCH1914 is offline   Reply With Quote
Old 12-12-2003, 03:20 PM   #14
miket
miket's Avatar
pics?
Old 12-12-2003, 06:18 PM   #15
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I didn't see this earlier but, I have 2.5" spindles 1.5" springs and 8" 4x4 rallies on mine, I also have 255/60/15 bfg's on the front. It does not rub at all. Like said before, It will hit the bumpstops before it rubs.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
